Question about Rockford Fosgate Punch 401S Car Audio Amplifier
Hello. I have a punch 551 4 channel amp. The
Hello. I have a punch 551 4 channel amp. The power is blown and found 3 transistors blown. Can this amps be repairable at a reasonable cost? I was told that all 6 transistors have to be replaced because it is all one bank. Thanks, Al
  • 631 Answers
The cost of the replacement parts is minimal if there is no damage to the audio circuit. If there are shorted output transistors, the cost of replacement parts won't be significantly higher but it may be more difficult to repair. If you're going to try to repair it yourself, read through the following page:
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
Posted on Jul 18, 2009
Playing too loud music has blown my amp
maybe because your amp is overload, try to load 8 ohms single speaker per channel, then try to playing loud, if blown your amp again, the power transistors bias maybe excess to 0.6V ' if transistorized, if IC power amp, check cooling fan.
Aug 06, 2011 | Denon Audio Players & Recorders
No power after i unhooked the wire from amp, left wire uncovered at ends for couple days tried hooking them back up and no power now. is amp blown
if you unhooked the wire from the amp while the amp was on, you may have possibly blown a fuse, or mayb a transistor or compacitor inside the amp! easy fix, just find new transistors and compacitors and soilder them on after removing old ones!
May 03, 2010 | Rockford Fosgate Punch P8002 Car Audio...
I have a rockford fosgate 550 that the fuse blows
Short inside one of the transistors. This requires very good soldring skills and electrical know-how, and some thermal paste to go between the heat-sink and the transistor. Unfortunatly this is not a cheap repair, probably cost around 100 dollars.
Cheers,
Kevin
Feb 09, 2010 | Rockford Fosgate Punch P550.2 2-Channel...
Power transistor number
Hi again! Been thinking about this and you might not need to wait for someone to answer. I assume the transistor in question has blown apart or burnt up so you can't read the number?
However does it come off the heatsink as part of the main amp? If it does then it might have a brother around it. For if it is say the left or right channel transistor, then the other channel will have the same type transistor. Remember the left and right channels are copies of one another. If you see 4 transistors on the heat sink then it's a push-pull amp. They work in pairs, one pair for each channel. By the way it's best to replace the pair, even if only one is blown.
If on the other hand the blown transistor is from the power supply section, then you will have to wait for someone to help, or get the service manual.
Jan 24, 2010 | Audio Players & Recorders
Amp powers up. the right channel works fine left not at all
If you didn't find any burned parts that would mean one of the buffer amplifiers before the power amp could have died. They could either be transistor based or opamp based. They are fairly low power so they will not explode like the output transistors like to do. Contact rockford, they should be able to send you a schematic. Let me know I will try to help you through it.
Dec 14, 2009 | Rockford Fosgate Punch 401S Car Audio...
ADCOM GFA 5802 POWER AMP NO SOUND, BUT POWERS UP.
Remove the output transistors and measure each of the sets of 3 pads and report the voltage readings here. I suspect that you have either a blown driver circuit or output transistors. The voltage readings will give me an idea on where to start looking for specifics.
Thanks,
Dan
Nov 11, 2008 | Adcom GFA-5802 2-Channel Amplifier
Bose SA-3 Amp / Blown Fuse
The problem is not the transformer. You now have shorted output transistors at the very least. By corssing the wires you presented a zero(0) ohm impedence load to the output section. It quickly went into overload. Before the fuses had a chance to open up, the outputs fried. This unit will require new output transistors and perhaps the previous driver circuit will require parts as well. Figure on $20-$50 in parts plus hte local labor rate for the repair.
Dan
Sep 25, 2008 | Bose Lifestyle SA-3 2-Channel Amplifier
DENON AVR 1906
Units dc protect mode is probably activating due to Blown channel (shorted output transistors) I work for a Denon Authorized repair Center in Michigan If shipping to Michigan is economical let me know kstahl65@att.net
Feb 05, 2008 | Denon AVR-1906 Receiver
Kicker amp troubleshooting
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 01, 2007 | Car Audio & Video
Blown fuse
This can be caused by too low of an impedance from the way the speakers are wired, bad speakers, crossed/shorted speaker wires, and sometimes even a poor charging system (if the amp goes into protect when the volume is turned up) and is usually what the problem is 95% of the time. As you said, very possible to be shorted output devices or shorted power supply rectifiers. Beyond that, it could be a shorted filter cap, some sort of short across the power rails, some sort of short across the output, shorts across the primary. And of course loose hardware - any missing screws or nuts? A loose one under a pc board can short out most anything.
Oct 02, 2006 | Rockford Fosgate Punch 801X Car Audio...
Rockford Fosgate Punch 401S Car Audio Amplifier Logo
326 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
