Question about Boating
After siting for winter, just bought new battery. engine is turning over but wont start. Radio, vhf. depth sounder, horn, etc is not working. checked all the fuses and there ok .any suggestions. I have a 1981 johnson 150 v6.
  • 86 Answers
If you put a new battery in the boat then look around the battery and make 100% sure that you hooked up ALL of the accessory wires to both NEG and POS posts. Sounds dumb but I have come accross it multiple times. As for the engine, if it turns over but will not start then I am about 80% sure that you need to have your carbs cleaned. Fuel sits in the bowl of the carb, then after about 30 days starts to varnish, after varnish it starts to look like mollasses. Then spring comes around and you squeeze the fuel bulb and crank it over forcing that old **** into your idle jets. That is why it is really a good idea to have your carbs fogged before you store your boat for the winter.
Posted on Aug 02, 2009
I brought a Motorola VHF HT1250 radio off of eBay & I programmed it & tested it out & everything worked great for a few hours & then it beeped once & shut off & now will not come back on.
Returning the radio would be your best option. There are many factors which can cause a radio to go dead. Assuming you have checked your battery and battery contacts, and tried a known good battery, if your radio will not power up, there isn't much which can be done.
Best regards.
May 25, 2015 | Motorola Ht1250 Vhf 136-174mhz 128 Channel...
My 1997 cameo wont start and the radio dont turn on but the lights work and the horn works i bought a new battie but it wont start
There must be enough juice in the new battery to run the lights and horn. Check the starter. It should at least turn over trying to start on a new battery.
Mar 10, 2011 | Zebra Cameo 2 Printer
Depth sounder
the transducer has to be in the water or attached to the inside of the hull if fiberglass with no air between the hull and the transducer. It doesn't transmit thru air.
Mar 12, 2009 | Raymarine Boating
SUV WONT START
check you battery and battery cables...sounds like a big voltage drop
Feb 22, 2009 | 2002 Nissan Xterra
Older HUMMINGBIRD DEPTH SOUNDER LCR-3D . WAS WORKING FINE WHEN I PUT IT AWAY, NOW WONT POWER UP. HAVE CHECKED THE INPUT POWER AND IT IS OKAY. I DO NOT SEE A FUSE IN THE UNIT. ITEM IS OLDER UNIT BUT IS...
We have an old Hummingbird Depth Sounder (Wide 100, 94 model) and it turns on but must be on test mode or smething cause we can not get it off. Does anyone know or have a manual to solve this problem. Please help.
Aug 07, 2008 | Hummingbird GPS
Faria Depth finder
I've found this manuals in Faria's site:
Depth sounder:
http://faria-instruments.com/site_manuals/IS0091F.pdf
Bombardier Depth Sounder:
http://faria-instruments.com/site_manuals/IS0138_C_digital_depth_sounder_owners_manual.pdf
Depth Sounder, Flushmount:
http://faria-instruments.com/site_manuals/IS0141c.pdf
Depth Sounder, Flush Mounted, Remotely Switched:
http://faria-instruments.com/site_manuals/IS0229_A_Digital_depth_sounder.pdf
there are also other useful manuals in the bottom of the page:
http://www.faria-instruments.com/downloads.php
Jul 14, 2008 | Faria Boating
Depth Sounder does not display depth
I will see if I can get mine off the hull for testing. Still have found no procedure. Thinking about just replacing the sounder with another unit.
Jul 05, 2008 | Garmin 185 Sounder GPS Receiver
Icom vhf radio
i have the same unit. i get interferance from my depth finder wire touching the antena wire off the back of the radio. make sure that no wires are touching the antena wire.
Aug 12, 2007 | Icom M302 VHF Radio
Boating Logo
114 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
