Cell Phones Logo
Sunny Azarpour Posted on Aug 29, 2016
Instruction manual for Nokia 6234
I need to see how the SIM card is fitted
Kimberly Carver
Level 1:
Habit-Forming:
New Friend:
  • Contributor 10 Answers
  • Posted on Aug 29, 2016
Kimberly Carver
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
10
Questions
0
Helped
1408
Points
30
Here is the link to the PDF guide: http://www.manualslib.com/manual/112136/Nokia-6234.html
2answers
My Nokia 6234 is not accepting my sim card, i need Restriction code, my IMEI number is 359395002773712
your phone is lock
try these sites
http://www.gsmliberty.net/shop/nokia-6234-imei-unlock-codes-p-1758.html
http://sim-unlock.net/simlock/Nokia/6234/
RESTRICTION & MASTER CODE FOR NOKIA 6234. IMEI-359395003537405
Hi, To which network has your Nokia 6234 been locked to? The safest and easiest way to unlock a mobile phone is to unlock using unlock code. An unlock code for a Nokia mobile phone can be obtained either from the respective network provider or from any trusted vendor online. for example, An accurate unlock code for a Nokia 6234 can be obtained from www.simpleunlocking.com/nokia-6234/rs16wp9/ at affordable cost. This site provides accurate unlock codes for over thousands of mobile models at low cost with easy unlocking instructions.
UNLOCKING STEPS FOR NOKIA 6234
1 - Switch on your Nokia 6234 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6234.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6234 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6234 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6234
The master reset for a Nokia 6234 can be done through any Nokia Priority dealer.
Oct 22, 2012 • Cell Phones
5helpful
2answers
I have fogotten the security code
Security code cannot be reset by yourself..! So u must take it to the nearest nokia care..!! or try this www.nokialockcode.com/
Evrytime i put in my sim card, the phone requires a restriction code and i don't have it. Please help. IMEI: 359395004060555
you will able to unlock your phone here http://www.superunlockcodes.com/nokia-6234/rs12wp9/
They will provide the code when you enter your imei number,you just need to select your phone model and network provider
Nokia 6234 headset not connected but phone thinks it is the headset symbol is showing on my phone which means i cannot hear anything unless i put the phone on speaker or plug in the headset. when i take...
have you try to turn off your unit and try to open it again?
If still there you will need to normal reset your phone, try to save all your files, back it up , remove the memory card and the sim card and open your unit again
press *#7370# then if it required code then type this code 1234 or 12345 (unless you change the security code)
then try to open it again
How do i use my mobile in tenerife nokia6234
You can use your existing network provider sim - and Roam, but you will have heavy charges.
Alternatively, buy a local sim card in Tenerife and use that on your phone.
I hope this helps,
Thanks.
2helpful
2answers
Nokia 6234 Security Code
Hi
Its 12345 . For more information refer to the user manual for Nokia 6234 from the following link :
http://nds1.nokia.com/phones/files/main_page/Nokia_6234_Vodafone_UG_en.pdf
Thanks
Rylee
Restrition code for nokia 6234.
Clean the sim carl place with toothbrush sometimes when its dirt it makes troubles.
Jun 03, 2008 • Nokia 6230
Nokia 6234, New Zealand. Vodafone.
get new sim card
phone carrier will copy whats on sim to new sim card i didnt get charged for this i dont think they will you either
the roaming overseas always changes parmeters of phone for some odd reason
May 10, 2008 • Nokia 6230
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
