Question about HP Compaq Fp5315 15 Lcd Monitor With Speakers
HOW DO I FIX CLICKING SOUND AND BLINKING POWER LIGHT IN COMPAQ MONITOR FP5315. THE MONITOR FAILS TO POWER.
WHEN POWERED THE POWER SWITCH WILL BE BLINKING GREEN THEN TICKING SOUND LIKE CLOCK COMING FROM THE POWER BOARD. ANY HELP PLEASE. NNAMDI MBAMOBI
  • HP Master
  • 1,682 Answers
The power transistor on the SMPS of the monitor is blown,
you will need a skilled person to diagnose and replace the component
Posted on Sep 01, 2016
SOURCE:
Monitor keeps turning on and off? it wont even show the screen for more than a second or two and then switch to black again.
your LCD inverter is almost dead. the monitor itself actually remains on, but just goes to black each time the LCD inverter cuts out, since this is what supplies white light to the screen.
In case you wanted The FP5315 Users Guide, or 3 other HP documents for the HP FP5315 LCD Flat Panel Monitor:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=324205&
Jan 05, 2011 | HP Compaq FP5315 15" LCD Monitor
HP Compaq FP5315 (Black, Silver) lcd is bliking when i use
you need to repair or replace the power supply, the blinking means that the the voltage is not constant so it can be a problem of defective capacitors: 1000uF 16 et 470uf 25V, you have to take it to professionnel technician because it is dangerous for you, there is a hight voltage inside the monitor but if you have some knewledge about electronic and hight voltage you can do it by your self.
Dec 27, 2010 | HP Compaq FP5315 15" LCD Monitor
Compaq FP5315 screen turning off
check the same on bios screen for a long time if the same thing happnes need a repair.
Sep 10, 2009 | HP Compaq FP5315 15" LCD Monitor
FP5315 Speakers
Please right click on My computer->properties- hardware-device manager-- check if your sound device is working fine. PLease let us know if we continue further
Sep 24, 2008 | HP Compaq FP5315 15" LCD Monitor
Compaq fp5315
Dear Sir/madam,
Check the speaker output cable will be correctly plugged to CPU or not?. i.e line in, line out etc...
thanks
good luck
Jul 29, 2008 | HP Compaq FP5315 15" LCD Monitor
Monitor switches on and off
Normally like thise it sound like your have problem with the backlight insideLCD.There is one condition with LCD is that if the backlight inside blink or spoil then it just cut off the supply that mean screen become black.If you switch on again it work but after sometime it should should shutdown again.Ask technician the check for you,don't do it yourself cos inside high voltage...danger.
goodluck,takecare.
Apr 22, 2008 | HP Compaq FP5315 15" LCD Monitor
HP Compaq FP5315 15" LCD monitor
It needs the power supply board fixed. I have fixed several like this. It needs 5 or 6 capicitors and a 7.5v zener diode which is really easy to do if you know how to solder. If you dont know how to solder you need to take it to a repair man or buy a new one.
Feb 28, 2008 | HP Compaq FP5315 15" LCD Monitor
Monitor blinks
your monitor haveing power supply problume it is not swtiching properly
ashok
Jan 21, 2008 | HP Compaq FP5315 15" LCD Monitor
Monitor blinks
call the manufacturer. this monitor if mad by hyundai, which believe it is, is poorly mad and my customers have had many problems with them
Nov 03, 2007 | HP Compaq FP5315 15" LCD Monitor
HP Compaq Fp5315 15 Lcd Monitor With Speakers Logo
149 people viewed this question
Top HP Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
