Question about RCA HD61W66 61" Projection HDTV
R52wh77 3d raunbow picture and no convergence option in menu. Should I get a new TV?
  • 4 Answers
I believe the fuse part number is 259213. You can find it on ebay for $2.50
Posted on Sep 04, 2009
  • 147 Answers
There are 3 fuses in a row next to the flyback
transformer.solder all the pins on the flyback
and replace the middle fuse.check the other 2
fuses.this is very common with RCA.
Posted on Jul 18, 2009
RCA HD52W59YX35
just change the picture tube.
Dec 09, 2007 | RCA HD52W59 HDTV Projection Television
Picture not in focus
Devices: All projection TV's (HD or analog), especially Samsung
If its a Samsung HCN653W (or similar model), the first thing to try is the menu option named "Magic Focus", which tunes the set's focus.
Otherwise, it sounds like a job for a convergence. Perform a convergence procedure on your TV, and if the problem recurs within a few days/weeks, then your TV's 'convergence amplifier' board (aka "convergence amp board") is starting to fail.
This board may fail completely, in which case, your convergence procedure will fail to improve the picture.
A "convergence procedure" can be performed entirely by just using the appropriate setup menu option and your remote control.
This board may partially fail, in which case your convergence procedure will properly converge the Red, Blue, Green colors on just part of the screen, whereas a properly functioning convergence amp board will allow complete convergence of the colors across the entire screen.
Your TV's convergence procedure instructions will be found in your TV's Owners Manual.
At least one Projection TV manufacturer recommends that the consumer perform a convergence procedure every 30 days, but most TV owners find that excessive, and might only do one when (a) there's an evident color convergence problem in any part of the picture, or (b) once every 3-6 months.
How-to video: www.youtube.com/watch?v=esk4nYZKFcg
how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
cost to you: $zero
If the convergence amp board is bad, cost for a service call would be $300 (USD) plus $100 for a new board plus 50% markup on parts = about $450 (USD)
Cost to order a new board online: about $100 (USD) + shipping + sales tax.
Alternatively, if you can solder/desolder STK's (Power Amplifier Integrated Circuits), one can repair a convergence amp board for as little as $30 (USD) or so.
Dec 04, 2011 | Sony Televison & Video
The color has changed so that grass looks like burned out fields and flesh tones look sickly. the menu color options do not seem to do anything, and blues still look fine. help! Baseball games look...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems
Jun 25, 2011 | Televison & Video
The picture on my Mitsubishi WS-65511 TV suddenly went blurry (looks like a 3D movie without the glasses). Is there a menu option that I can use to fix it myself?
No,tv have a problems known as a convergence problems,it is dead.This problems it is the tv board that call the convergence board it is dead.This convergence board must require to be replace 2 STK convergence ICS and some or all of it resistors too on the convergence board too.To fixed the tv convergence board to solved the tv convergence picture.The shop,will cost u like $300-350 for parts and labors.
Apr 19, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
GE 60in Big Screen(Convergence won't Align)
do you know how to solder? If you do you can redolder the two convergence IC's on the convergence board and it will probably cure your problem. These IC's usually are against a large metal heat sink they stand up and have quite a few pins on them. If you try this you need a pencil solder iron and solder and do not solder any of the pins together.
Aug 10, 2009 | Toshiba TP55H60 55" Rear Projection...
Colors arched and overlapping
if the option for convergence is still listed under the setting section of the on screen menu, then you need a convergence power supply board. If the convergence option is missing from the menu you need the ITC222 convergence missing repair kit. You can get either one at the following link they include instructions for the repair.
http://www.tvrepairworld.com/
Jul 13, 2009 | RCA R52WM24 52" HDTV Projection Television
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
RCA HD61W66 61" Projection HDTV Logo
283 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
