Question about Sub-Zero Refrigerators
Refrigerator not cold enough on subzero 14 years old
dididsaythat
  • 291 Answers
SOURCE: Ge refrigerator not cold enough
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Posted on Sep 12, 2007
SOURCE: Subzero refrigerator (20 years old!)
Was able to get an Authorized Subzero company here this morning with NO emergency service charge. Turns out the fan needs to be replaced and it also needed freon.
Posted on Aug 03, 2008
  • 66 Answers
SOURCE: why does freezer get cold but not refrigerator side?
Check the freezer temp (available in most grocery and home improvement stores). The temp should be between 0-10 degrees F (not just barely below freezing).
You can also try to find a solution on www.repairclinic.com or click here.
Posted on Aug 13, 2009
  • 3741 Answers
SOURCE: refrigerator won't get cold enough
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section . For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 27, 2010
heatman101
  • 43501 Answers
SOURCE: My G.E Adora refrigerator freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 18, 2010
My subzero is cold, but not really cold
it could be the damper door isnt opening fully due to ice or the cold control is bad,or the motherboard that electronically operates the unit is bad,clue:: if you have recently burned out lights in the refrigerator and the digital temp read-out is now out this is the board gone bad,if you replaced the lights and now they dimly flash when you open the door and you have a rapid clicking noise in the rear area its the relay trying to latch,but the burned board wont let it,you will see the burned area upon removal on the plastic cover and board trace is burned away
Jan 26, 2010 | Refrigerators
The refridgerator side of my side by side subzero is not cod enough. the coils are clean..what do I do now? the freezer portion is cold but is producing ice at a very very slow rate. the refridgerator is...
You probably have a leak in the evaporator and there is not enough refrigerant left to cool properly. Sub Zero has a 12 year warranty so You may want to replace the unit. You need to call a servicer to check it out.
Sep 22, 2009 | Refrigerators
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
I have a 14 year old subzero 550 bottom freezer and it never gets cold enough. I vacuumed/cleaned the filter area, but I don't think it helped much. Anything else I should do? The problem however is not...
The compressor might be weak to pump the refrigerant to the top area resulting in poor cooling.
There could be a block in the system and the flow of refrigerant is blocked resulting in poor or partial cooling.
!4 years! It has out lived it's useful days and requires replacement and you could save on power bill by replacing the same with a new one.
Cheaper things are costlier on the long run!
Jul 10, 2009 | Refrigerators
SubZero fridge problems
Ice buildup on the back left wall is the sign of an evaporator leak. Not something you can fix yourself, at some point it is going to be completely out of gas, I would call for service now
Apr 07, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Refrigerator will not get cold
how old is thew frig? look at the data plate for the information. if its over 14 years old then no.
Mar 26, 2009 | Refrigerators
Subzero refrigerator (20 years old!) compressor is noisy and the frame of the refrigerator is very hot.
Aug 03, 2008 | Sub-Zero Refrigerators
Refrigerators Logo
459 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
