Question about Sony KDL-46XBR4 46 in. LCD Television
There are cloudy smear marks on my tv screen after using my screen cleaner....how do I remove these?
  • 147 Answers
You cant
Posted on Jul 18, 2009
What is the best to use to clean fingerprints on the screen? Soap and water or glass cleaner?
I always suggest Monster Screen cleaner, It is not alcohol based and is designed for cleaning LCD screens. I use this professionally in my tv shop, this stuff is great, even removes crayon marks.
http://www.youtube.com/watch?v=523NZbh_Qpo check out this guys review.
Aug 03, 2011 | Philips 32PFL3505D 32 in LCD TV
I have a very small cloudy type smear on my Olympus epl2 lcd screen. It's not a scratch because the surface is very smooth. What caused this and how can it be corrected? Cheers, Jim
I don't have an E-PL2 to look at, but it looks like there is a protective window over the LCD screen on the back of the camera, that is why it is smooth.
If the "cloudy smear" is see-through-cloudy, then it's either a water spot under the glass or dust.
If you can't see anything on the LCD in that spot but big splotch, then the LCD is cracked and needs to be replaced.
Without being able to see it, I can't say 100% sorry.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Cameras
Suddenly my asko dishwasher is not cleaning my dishes effectivelyl-- there are cloudy smears all over my glass ware & cutlery-- I use a rinsing agent, but it makes it all worse.
soak the cloudy glass ware in white vinegar for at least 5 minutes. If you can remove it, it could be hard water. You need to adjust your detergent amount. Have you changed detergents ? If so use a high quality brand.
If vinegar doesn't remove the smears, it is probably etching that is caused by hard water, too hot water or prerinsing
Sep 17, 2010 | Asko Dishwashers
A-65 screen has fine scratches/clouds
My Raymarine A65 was so bad in daylight I could not read the screen. Used Never Dull polish from ACE hardware, similar to Brasso, and it took every scratch and cloudy mark off the screen. The can documentation includes glass as one of the items it?s safe to use on. Looks new again, Good Luck, Paul
Apr 08, 2009 | Raymarine A65 Combo GPS...
Water marks on stainless profiles
I have used Bon Ami or Bar tenders Stainless steel cleaner (found in the section of Ajax or Comet Cleaner). Put some of the powder on soft cloth, wet it a little & scrub mark lightly; use clean rag w/water to clean off powder. Then use stainless steal spray cleaner (like the one found at Bath & Beyond) and rub in with soft cloth. I have found that the pull-out stainless steel cleaner wipes are too wet & just smear. Good luck
Dec 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
Cleaning black front panel
Depending on what type of screen you TV has, many have plastic frenel screens that react to certain cleaners such as ammonia and alchohol based. These compounds can permanently damage the screen causing a cloudy area where it was sprayed. Unfortunately nothing can be done except to replace the screen.
Mar 14, 2008 | Sony KP-51HW40 51" Rear Projection...
Philips 55p8342 chassis ptv916
To get a new remote call a local TV service company or you can order directly from the manufacture. The cloudiness of your colors are caused by possibility of two things or both: 1) The mirror and lenses inside your TV need cleaning (use window cleaner & soft cloth) spray liquid onto cloth, 2) The fluid in picture tubes need to replaced. To replace fluid (ethylene glycol) take tubes out of unit, drain fluid, clean fluid chamber, add new fluid. How you can tell if fluid is cloudy? Take off screen assembly look into each light (red, green, blue) the picture should be clear. The red tube, light, is normally okay, so use as referance.
Feb 16, 2008 | Philips 50P8341 50" Rear Projection...
Cloudy TV Screen
If you can remove the front screen, look down into each CRT tube lens, blue, green & red see which ones are cloudy. The cloudy ones need the fluid changed which is a coolant. Shops charge between $75 to $150 a tube to change.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
Sony KDL-46XBR4 46 in. LCD Television Logo
994 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
