Question about LG Televison & Video
LG DVD Player DK9821P and Sony TV
When I try to connect my new LG DVD Player DK9821P to my Sony TV, the image appeared black and white. I tried connecting it to my brother's TV set, it appears okay, the color appeared already. Why is it that my LG DVD Player DK9821P does not work with my Sony TV? Please help. Thank you very much.
sambhu dayal
SOURCE: NO color output
DAV-DZ3k is a good sony product especially ...famous for book shelf speakers,the problem is basically due to the cables used to connect video terminals or the TVcircuits is not proper with the av receiver.. Thank you Regards Sambhu Dayal
Posted on Oct 07, 2007
dobhan
  • 105 Answers
SOURCE: color to black and white and back again
Try to check the TV system it might be set to PAL or NTSC...
Posted on Jul 08, 2008
weaponx69
  • 58 Answers
SOURCE: DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Posted on Jan 12, 2009
SOURCE: i am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Posted on Jan 31, 2009
TWITCHDADDY
  • 54 Answers
SOURCE: connecting new Sony DVD player to a TV, VCR, & Comcast cable box
wheres the dvd hooked up
Posted on Feb 14, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Hooked up cable box, wii box and dvd player to new lg 50 inch 720p plasma tv... all external components work, however, dvds and wii only show in black and white - no color...
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Dec 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
Trying to hook up a Philips 22'' TV to Sony CD/DVD player. Need help. I have a Red, White. and Black connector to go from TV to CD Player. Do I need anytning else? TV model # 22PFL3504D/F7
Usually the Color Red and White is for the audio channels and yellow is for the video but in your case you find black instead of yellow.
So you do the connection as per the instruction given below.
TV DVD Player
Red--------------Red
White------------White
Black-------------Yellow
Jul 25, 2009 | Televison & Video
Recently bought a Sony Bravia 20KDLS4000. Sony DVD player DVD-NS575P was compatible with 3 year old Sony TV but with Bravia, the DVD image is in Black and White. TV gets color fine. Thanks for your...
Try to set your video output settings on your dvd player . I assume you used to connect to your old tv by using svideo and now you are using another connection like component, scart or hdmi.If the video output setttings on your dvd are still on svideo you will have to set it to rgb or component or else you will get black and white images..
Sep 29, 2008 | Televison & Video
Dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Aug 06, 2008 | Sony DVP-S500D DVD Player
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
Televison & Video Logo
140 people viewed this question
Computer Repairing
Computer Repairing
