I have to replace my Carrier coil.
I'm still in my warranty period. barely.
So, I will get the coil paid for, but the service is over $450.
I am in total agreement that this is a manufacturer defect and should be recalled.
My tech said Carrier coils before 3 years ago were poorly designed. The tray beneath the coil didn't slope much, so up to 1/2" of water would sit on the coil and deteriorate it. Apparently they have built a better slope to the tray into the newer coil design, so our replacement should be better.
Problem #2. I have two units in my basement. I'm sure it's just a matter of time before the other goes out, and it won't be under warranty.
To add insult to injury, I had a Carrier unit installed in our last house and had to replace the A-coil on that unit too!!! Frustrating!!!
If Carrier does not pay for repairs and replacement of either unit, I will never use them again and will feel compelled to preach on every forum I can to spread the word that Carrier should be avoided.
What are your thoughts.
  • bill262 Jul 18, 2009
    Not sure what you're asking for me to clarify.
    I really just want advice on what I should do to fix the situation and to limit my cash outlay.
    Sorry if I sounded angry, but i just found out about the latest problem and was venting.
  • Ken Bledsoe May 11, 2010
    thanks for the info. Hard to believe that the mad scientist in the lab missed something like that. So simple the slope of a A Coil is number one I would have thought.
  • 614 Answers
Carrier did have some problem with coils but not as much aas Trane and other companies did. Contact Carrier direct and tell them whats going on and that you have always trusted Carrier to have a good product. They may pay for aprt of your coil replacment.Russ Carrier Dealer
Posted on Jul 18, 2009
John. Heidel@MSSB.com I have 2 carrier units both installed in 2006 and still under warranty, they are a 38brc030 and 38brc042 the evaporator coil in both units have to be replaced and the compressor coil...
The best thing to do is to call Carriers customer service line or their tech. support number... often times the customer talking to the co. directly will get better results then the dealer talking to them...
The dealer does need to recover thier costs also... they do not make that much money on the initial installation...
It is worth a phone call or two for you to call the factory and tell them how you are going to tell all of your friends NEVER to buy any carrier products because they do not stannd behind them!!!
heatman101
Aug 19, 2010 | Carrier 38BRC036 Air Conditioner
We have recently had three problems with our three year old Carrier 24 ACA airconditioner that I believe has led to it no longer producing the low temp. chilled air it did when it was installed. !. water...
Your air temp should be at least 20 degrees cooler than the indoor air temp. This is ideal. But it sound like your unit is low on freon. When units get low they will freeze up. They will also freeze up if air flow is restricted on the inside coil or the fan quits on the external unit.
Aug 08, 2010 | Carrier 38CKC024 Air Conditioner
Looking for evaporator coil cd5axa036017abaa . three years of recharging rather then fixing now the coil is out of warranty and Carrier and service company will not stand behind product.
Hi, if you have a leak in the evaporator coil which this happens a lot and they came out and didn't try to make any attempts in finding and repairing the leak or they found it in the coil and didn't order a new one, this is against the law by E.P.A standards. They must make every attempt in making the repairs if it means replacing the coil, no if, ands, or buts!! Keep your receipts on them charging the system. Now that its out of warranty, I would call them and bring this up about not changing out the coil when the leak was found. I am sure they used dye to locate it.I have found more leaks in the evaporator coils then I care to count, and had to replace the coil. This is something you can't do on your own I must say, as it takes special equipment to do this job. I would call the Enviormental protection agency and tell Carrier you will do this, and report them. I bet they will stand behind it then. You have to get tough with them. I am a air conditioning contractor and know the law. The E. P. A. will get them on the ball trust me. This is bull+)_(*&%!* !! Don't let Carrier walk on you, this coil should have been put in the schedule to be changed out right away, not to continue to charge it to get you through. This is a 3 ton split system. Stay on them, this will be covered if you make the call and stay on them. The E. P. A. are very strict on this as this is why they have stopped us from venting freon into the air, they have very strict guide lines we must follow and Carrier did not follow them on your unit. Please keep me posted, and the best to you.
Sincerely,
Shastalaker7
Mar 26, 2010 | Carrier 38CKC030 Air Conditioner
My blackberry ball fell apart what do i do?
Please go to the nearest service centre and replace the track ball.I also suggest you to contact your service provider (customer care) and check wheather its under warranty period..
Nov 17, 2009 | AT&T Blackberry Curve 8300 Smartphone
Evaporator coil needs to be replace again. Installed w new manufactured home; 09/2005. Replaced 05/30/08. Needs to be replaced again 09/17/09. All due to leaks. Freon was added. Currently has small leak;...
the manufacture is only required to supply the part free of charge thru its warranty period. the installing company probably would only give a 1year labor warranty and honor the pparts thru the manufacture for 5 years but unless you paid additinal for an extended labor warranty i dont think you are going to have much luck. Make sure you change your air filters every 30 days a dirty filter is one of the biggest causes of evap coils prematurely leaking. Sorry wish i could be more help.
Sep 17, 2009 | Intertherm P3RA-042K Air Conditioner
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Skyfi2 fm modulator
From the user's manual page 31
You may call Delphi at 1.877.GO DELPHI (1.877.463.3574). If service is needed at any time during
the warranty period, the purchaser will be required to furnish a sales receipt/proof of purchase indicating the date of purchase, amount paid, and place of purchase.
Customers who fail to provide such proof of purchase,or I assume when the product is out of the warranty period, will be charged for the repair/replacement of any Product.
Aug 18, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Carrier evaporator coil
I recently contacted Carrier Corp after our routine annual HVAC check on our residential system indicated that our 4 ton AC unit and 3 ton unit had leaking evaporator coils.
They basically told me to shove it in a very curt letter - In other words even though a leaking evaporator coil is a manufacturing defect they will not offer any financial assistance in replacing the failed evaporator coils.
I spoke to several HVAC engineers and they indicated Carrier has a high percentage of evaporator coils and compressor failures on residental HVAC systems.
The copper wall of the evaporator coil is being drawn thinner than in earlier years and the R22 being acidic slowly eats through the copper tubing.
Evaporator coils should not fail according to the HVAC Engineers if properly manufactured.
The Bear
May 19, 2008 | Heating & Cooling
Cursor aspire 5720
Its you mouse pad problem plz get it repaired under warranty period or at service station using paid services
Dec 06, 2007 | Audio Players & Recorders
Heating & Cooling Logo
362 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
