Question about JVC GR-DVL120U Camcorder
JVC GR-DVL120U Camcorder Problem - No display in view finder
JVC-GR DVL120 U camorder.I am from india, i bought it from US 4 years back .I am now in india. NO DISPLAY IN VIEW FINDER.but normal operation(playback/rec)are working.
FYI.Camcorder usage occasional. pl,provider info abt the problem and nearby service station for assistance.
mail your reply to ,
magic seadog
  • 38 Answers
SOURCE: JVC 700 dv: Both the monitor & view finder are pitch black, I can't see objects in front of the camera through the camera
Sorry, The bad news is you need to send it to JVC factory service for repair. The good news is they will fix it for free. It has a failed ccd which was a mass prduction problem. Go to You'll see your model number in the list. Just follw directions from there. Good luck! magic seadog
Posted on Aug 12, 2007
  • 53 Answers
SOURCE: jvc gr-d3ou video camera
Apparently this same problem exists on many different models. I have a JVC grd72u. I called JVC @ 800-252-5722. I selected the "Corrective Action Program" prompt from the automated attendent. I spoke to a customer service rep. They are aware of the problem and are fixing it for free, but only until 12/31/07. I suggest you call ASAP and get your name in the computer. If the problem is something besides the CCD sensor, they will call you with the estimate to repair.
Posted on Dec 28, 2007
  • 156 Answers
SOURCE: Lens Cap Warning & Gray Distorted Display
Posted on Jan 01, 2008
SOURCE: jvc gr-d73 ek mini dv digital
for everybody:
please give me the driver of jvc model gr-d73ag, at this email :
thanks before...
Posted on Feb 04, 2008
  • 156 Answers
SOURCE: JVC GR-D250 Mini DV Digital Camcorder Authorised service center in pune india
This model is not supporting with pc when you play cassette only it is supporting with memory stick
Posted on Feb 28, 2008
SOURCE: JVC compact VHS camcorder will not record.
i'm sorry i dont have a suggestion, but i do have a problem with the focus on my camcorder everything works except the picture on it. and i've bought the vhs-c vcr converter tape to go with it. i would like a manual for it and cant seem to find the right sight to print off a manual
Posted on Mar 28, 2008
0 characters
1 Points
Turn on the unit and goes to full zoom. Back it off manually, it will immediately return to full zoom. Unit was bought new about 6 years ago.
My camera did the turned out to be a sticking zoom switch. With the camera turned OFF... move the zoom button ON TOP ( above the view finder) of the camera to the left and right about 20 or 30 times... then turn the camera on and try it.... very simple... but it worked for me :o)
Dec 04, 2010 | JVC GR-DX307 Mini DV Digital Camcorder
I bought a JVC GR-SXM250u Super VHS camcorder a couple days ago and the picture has horizontal lines flashing in and out so I can't see in the display both in pause mode and in record mode. He said he...
you may have a faulty camera there,,,or the vcr tape may be faulty and has spred some of the tape on the recording head try running a cleaning tape through the vcr first to clean the heads,,then use a new tape (not the old tape!) to try that out,, if its cleans the head up throw away the old tape so you never put it back in this vcr
Sep 04, 2010 | JVC GRD250 MiniDV Digital Camcorder
Cassette door is not closing
Your loading motor is no longer working or your mechanism is out of alignment.
Aug 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Lens cover problem with jvc GR-DX27
Call JVC customer service - i have exact same prob - called them today they picking up camera wed and repairing for free.!!
Jun 12, 2008 | JVC GR-DX25 Mini DV Digital Camcorder
JVC GR-DX76 - No Picture
which view finder? contrast or brightness?
Apr 22, 2008 | JVC GR-DX76 Camcorder
best buy... firewire i believe its a "4 to 6" or a "4 to 8" its basically a usb to the camera which plugs into the "DV" slot on the inside of the screen.
Mar 09, 2008 | JVC GR-DVL120 Mini DV Camcorder
CCD Failure/Lens Cap Warning Error JVC has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty.
Please call our Consumer Support Department on 0870-330-5000 to obtain your free repair. We apologise for any inconvenience and we appreciate your understanding and support.
Please note that this offer expires on 30th June 2009 and is applicable only to failure of the CCD image sensor.
This information applies to the following models:
GR-D18, GR-D20, GR-D21, GR-D22, GR-D225, GR-D23, GR-D24, GR-D30, GR-D31, GR-D32, GR-D33, GR-D34, GR-D40, GR-D43, GR-D50, GR-D53, GR-D54, GR-D60, GR-D63, GR-D70, GR-D73, GR-DX25, GR-DX27, GR-DX28, GR-DX35, GR-DX36, GR-DX37, GR-DX45, GR-DX47, GR-DX48, GR-DX55, GR-DX57, GR-DX67, GR-DX75, GR-DX77, GR-DX78, GR-DX95, GR-DX97, GR-FX15, GR-FX16, GR-FXM39, GR-FXM393, GR-FXM40, GR-FXM404, GR-PD1, GR-SX19, GR-SX25, GR-SX26, GR-SXM29, GR-SXM30, GR-SXM49, GR-SXM50, JY-HD10.
Jan 01, 2008 | JVC GR-D20EK Camcorder
JVC GR-DVL120 Playback
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
My JVC Camcorder's screen is black and won't record.
See if your camcorder is listed on the JVC site for free repair...apparently this was a common problem.
Nov 14, 2007 | JVC GR-DVL120 Mini DV Camcorder
Gr-dvx7 jvc lcd screen is just white?
If the view finder shows the same white display. You probably have display circuit problem in the camera. Faulty CCD chip usually shows Black screen so it probably board problem or a connector problem. If you see an image through view finder then you may have defective connection from board to LCD assy. Either way it need to be looked at by a trained technician. Good luck.
Mar 17, 2007 | JVC GR-DVX7 Mini DV Digital Camcorder
JVC GR-DVL120U Camcorder Logo
57 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Shekar Avadhani
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
