Question about Kenmore Vacuums
Vacuum stopped as it got plugged up with fuzzy carpet stuff..cleaned it out but now it won't start.
    Sniper:
  • 84 Answers
This is due to the thermostat. If the cleaner can't breathe the motor will shut off if it gets hot. If you have new carpet, this will be a problem for a little while, until your carpet stops "shedding" unclog and wait. after cooling the unit will once again function. If it is your power nozzle, then unplug roller and push the reset button while turned on, and you should have no more trouble! Hope this helps!
Posted on Jul 18, 2009
I have a eureka 4D boss vacuum that won't go into barefloor mode and has no suction in carpet mode
turn the beater head over and see if something is stuck ours was totally plugged with stuff till I cleaned it last week for wife .
Dec 24, 2015 | Eureka Vacuums
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
Why is my carpeting getting fuzzy tips?
You might be vacuuming too much or you may have the wrong brush strips for your style of carpeting. I recommend you take a sample of your carpet to your Riccar dealer and ask them if you have the correct vacuum and brush strips for your type of carpet.
Aug 02, 2014 | Riccar 12 8000 Simplicity 7000 Type B...
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
Sebo k3 won't vac on carpet...only hard floor
Do you mean the beater bar stops turning and then it doesn't vacuum?
Or it shuts off when you jam it full of carpet? Read the below manual:
http://www.sebo.us/pdfs/website_owners_manualsPDFs/AIRBELT%20K%20Manual.pdf
Aug 27, 2012 | Sebo Air belt K3 Bagged Canister Vacuum
The suction is good, but it can't pick up most of the stuff on the floor. The hand held hose works very well, but it doesn't even pick up little fuzzies reliably when I push it along. And, the suction is...
Check entire length of hose, including the piece in the power head, for clogs. Simply drop a marble in one end and allow it to roll out the other. If it doesn't, then the hose is clogged somewhere.
Aug 22, 2010 | Dyson DCO7 Animal Bagless Upright Cyclonic...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell 9200 Proheat 2x carpet cleaner
cleaner will not start
yes, I plugged it in!
Aug 07, 2008 | Bissell 9200 Upright Vacuum
How I clean the machine?
Take the front piece off, there is one screw in the center of it, on the top, Then remove the 2 clear covers, one on each side. then you can get in there to clean the brushes, also can take them off if you want to.
May 13, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
142 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
