Question about KitchenAid KUDK03ITBK Built-in Dishwasher
The dishwaher is going through the cycle but the macine is not washing. I checked the overflow float
    Sergeant:
    Champion:
  • 205 Answers
Filter might be choked (blocked) and because of this pump is not able to lift the water for gentle cleaning.so please check the filter and the pump head.
Posted on Jul 26, 2009
Aldi washing machine overflows the washing bin as the auto matic cut off does not engage.
test and check water level switch and connections for failure or damage
Apr 20, 2017 | Washing Machines
Tip
Whirpool dishwasher overflowing water
If during the wash cycle your dishwasher overflows it could be
because the float is sticking. It is on the front right and has a switch so
that when it floats high enough the water stops.
on Sep 20, 2010 | Washing Machines
Our dishwasher will not power on. we replaced the main fuse and have nothing for power
Check for a stuck water level float. There is usually a little plastic cover with a float under it. Scum accumulates and the float sticks in the up position, causing the dishwaher "brain" to think that the water level is already full. The dishwasher naturally refuses to start a cycle. If this is not the cause, it may be more severe such as a fried logic board (if your dishwasher is computerized). It also may be a failure of the switch that senses when the door is closed. Check the float first.
Feb 18, 2011 | Frigidaire Dishwashers
The "floating drum makes out of round knocking noise in spin cycl
On the bottom of the washer tub is a "balance block?" that the bolt has loosened on. Have GE come repair it. We just had it happen to us as well. If you don't get it repaired it will cause more damage to the washer and then it won't be covered under the warrenty.
Jun 01, 2010 | GE Profile WPRE6150KWT Colossal Capacity...
While on the rinse cycle it trickles, drips slow. the wash cycle runs great. any idea?
check the inlet valve screen, often located at hose connection at back of macine.
Replace hoses every 5 years...
Oct 10, 2009 | Washing Machines
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Brand new dishwasher stops mid-way through wash cycle with soap spilled out all over the door. Can't seem to get past the wash cycle to finish the complete wash/dry cycle.
if there is no water in the bottom of machine, see if your water supply is turned off, or check for a loose wire on the water valve, lastly, check if the float is stuck in the up position. That is the overflow protector. If the machine 'thinks' the water level is too high, it will not allow more water into it. The float is in the front left corner, usually under a raised cover, remove that cover and manually raise and lower the float to allow free movement. It should be normally in the down position. Good luck.
Aug 20, 2008 | KitchenAid Dishwashers
Overflow
If you unplug the machine and the water still comes in, you have a bad Water Inlet Valve. If when you turn the machine on at in overfills and you can stop the water by turning off the washer timer then you have one of a couple possible issues.
First, you pressure sensing tube could be clogged
Second, you just plain have a defective pressure sensing switch.
If you have anymore questions, feel free to comment back.
Thank you
Mar 26, 2008 | Hotpoint VBSR3100D Top Load Washer
KitchenAid KUDK03ITBK Built-in Dishwasher Logo
118 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
