Big Screen gets loud, mad and turns off
Our television makes a loud whirring noise at the back of the set and then the power button lights up "fan" and "lamp" and then at the bottom "system" something. It looks like a mad face. Two eyebrows and a straight mouth. The color starts to go and then it eventually turns itself off. Help.
  • PHANTOMAN Jul 04, 2008
Well if its a Sharp 65DR650 model then your color wheel is shot. The color wheel spins and it wears out on this model television. I had the same problem with two others and multiple others had same problem on the internet. Our had the noise and after being on a while the colors started messing up then it would shut off. To fix it you need to get sharp to release a light engine to fix it. But when we checked they were backordered with no sign of any ever being shipped. So we junked the two sets we had.
Posted on Dec 19, 2007
  • 111 Answers
Without a model number, i can't be much help. if this is a newer dlp or similar tv, the fan is probably going out. some newer tv's have a fan that is part of the light assembly, some have a separate fan.. the loud whirring noise is usually caused by bad bearings or the blades of the fan may have become unbalanced, either way, the fan making the noise will need replacing. the color going is usually caused by the lcd or dlp overheating and/or the lamp overheating.
if the tv is out of warranty, remove the back panel, locate the fan making the noise, and search for a replacement. if you have a model number, i can check around and see if i can find the part number for you.
hope this helps,
Posted on Nov 19, 2007
Packard Bell oneTwo L5351
hmmm.. seems had a problem directly on the hardware side of your computer. my only and good recommendations to you is, first, check if your packard bell desktop has or still have a Warranty, if its on warranty, you can go to the service center to check the hardware of your PC. Second, if your computer is Out of Warranty you can check it by your self, open your CPU Drive, clean the dust inside the Hardware then check everything if all the wire's are still INTACT to each other.
Apr 03, 2014 | Packard Bell Computers & Internet
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
My ps3 320gb has frozen i cannot get the game out
Turn the PS3 off as normal, then turn the power off by flipping the switch at the back so that no light are on the console at all. Once the console is off fully, hold the eject button as you flip the power switch at the back on. The PS3 should start with a loud fan whirring noise. Once powered up, release then press the eject button once or twice and it should force the game to eject.
Best of luck!
Mar 06, 2011 | Video Game Consoles & Games
Toshiba 42HM66 has a whirring noise that stops when power off
this is a bad color wheel, however you cannot just change the color wheel on this set you have to replace the entire light engine.
Dec 06, 2009 | Toshiba 42HM66 42" Projection HDTV
Our LG bottom freezer refridgerator is 2 years old. It is making a whirring noise that stops when the door is opened. It can get pretty loud at times.
The whirring sound is the fan that blows cold air into the refrigerator. It is supposed to stop when the door is opened. If it is making a loud noise there may be ice built up in the fan housing. Turning the power to the refrigerator off for a 2-4 hours may allow any ice in the fan to melt. If you do not open the freezer during that time the frozen food will not defrost.If the noise continues, you may have to take the fan apart to make sure it is not frozen. It is probably located behind the back inside panel of the freezer.
Nov 02, 2009 | Refrigerators
I have a samsung HLP4663W DLP tv. There was a loud whirring noise inside the set. The light was still working and the fan also. I turned it off for a few minutes and turned it back on and it did the...
your color wheel is bad. Let me know if you would like me to post a link where you can get a replacement with free installation instructions with free tech support.
Apr 26, 2008 | Televison & Video
Loud whirring. Not the fan.
The fan noise is normal on this set. The lamps are cooled via this method. Your users manual explains this issue..and it is the fan as you can see it slows down after the tv is switched off..
Oct 20, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Big screen t.v. UltraVision
take it to a tech for repairs the power supply iis defected 0r related circuit.good luck.
May 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Check the Lamp it is consumable and you will replace it every couple of years it is user replaceable and should have info in your owners manual. they run a couple hundred or so.
Televison & Video Logo
326 people viewed this question
Top Televison & Video Experts
