Question about Whirlpool LSQ9549P Top Load Washer
WHIRLPOOL MODEL LA5200XTW1, TOPLOAD, FILLS, SPINS BUT WILL NOT DRAIN WATER.
Master_Tech
  • 770 Answers
SOURCE: Water Does Not Drain
You may need to Clean out the pump catch to do this you need to remove the drain pump access cover, insert a pointed object (or tool) into the hole, Bottom right front of the unit push in to release the latch and rotate the cover clockwise.
you will need to clean this out use a shop vac to remove the water in the unit or have plenty towels handy
AS far as the fault code
E:04=Er:04washing=Door control broken
Cause=Faulty Triac or control module
Posted on Feb 17, 2008
SOURCE: washer does not drain water
Make sure the drain hose is not kinked
Posted on Jul 20, 2008
SOURCE: Transmission problem of a washer Whirlpool model LXR7244JQO
Good morning.
The problem lays in the transmission. From outside when you turn the universal (connector) the bowl with the brakes don't turn with the main shaft. When you open the transmission, remove the clip of the big plastic gear. After you lift up the plastic gear you will notice that one or two of the plastic parts are worn down. By replacing you will solve the problem.
Posted on Jan 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool sm 8280867 - aggitor does not
You lid switch is most likely to blame.
To check it - jumper out the 2 wires at the switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 03, 2009
scottludwig3
  • 4 Answers
SOURCE: bleach dispenser does not drain water
i just had the same prob i took off the top snap cover for the bleach and saw were the water goes out and it was clogged cleaned it out and it drains great again
Posted on Nov 17, 2009
What is the minimum length of drain tube for whirlpool topload washer, & how should it be plumbed
washing machine drain hoses should be higher than the full water level before the drain
hanging the hose over the washing tubs edge is the correct height
as there is no valve or solenoid tap in the drain system, if the hose is placed on the floor , it will never fill so the high point is where the washer water will fill to until the control shuts the inlet water off
May 29, 2017 | Whirlpool Washing Machines
I have purchased a samsung sw70g9 topload model.my probem is that when water fills the tub it will drain automatically as well in the drain hose..i need an answer please help.thankyou.
A drain valve that is supposed to close according to the setting on the machine is not doing so, probably due to a problem with the circuit board or with the solenoid that closes the drain. You need in person diagnosis.
Feb 16, 2014 | Samsung SW62ASP Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool Ultimate II topload fills with water but does nothing else. The lid switch appears OK
it might look ok but not all the time it is. If the switch is good, maybe it is a burnt or bad connection at the motor. or it could be a bad motor
Mar 01, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool 8525079 topload washer fills with water but does nothing else
Lid switch should 'click' when lid lowered. May need to be renewed if you can't hear this.
Feb 27, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Cycle stops motor hums whirlpool top load
bad points in timer or bad motor take the motor out and to a used washer shop and see if they will test it for you for a small fee if it tests ok get a timer
Dec 25, 2009 | Whirlpool Washing Machines
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool LSQ9549P Top Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
