Question about Samsung Cell Phones
How do I enter a pin no into the GT S5230 after turning the phone on? In the basic functions it says "press & hold on key then enter your pin and select confirm. Cannot see any mention of a pin in the user manual. Thanks
What is the best mobile flasher for all type of mobiles
Posted on Aug 17, 2009
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
Tip
LG E612 Hard Reset Google Lock
With article and troubleshooting guide solution for LG E612 Hard Reset Google Lock
  • Method (1): Backup PIN & Google Account.
  • On the pattern locked screen, click on the "forgot pattern" button .
  • You will be asked to enter Backup PIN & Gmail ID & password that was being used in the phone
  • Phone will be unlocked once you have provided Backup PIN ,Google account ID and correct password.
  • Note: No user data will be erased in while resetting pattern with above method
  • Method (2) : Pattern unlock with hard reset.
  • If you do not remember Backup PIN or the Gmail ID & Password details or you has not logged in with his Gmail ID then you should perform hard reset.
  • Note:This method will erase all user data and settings from the phone. and process is irreversible.
  • Make sure phone is Powered Off.
  • Press & Hold the "Volume Down Key (V-)" and "Power button" altogether
  • As LED at the bottom of the phone lights up, Release both pressed keys (V- and Power key)
  • Just after releasing the keys, press & hold "Home" key for about two seconds.
  • The phone will turn ON & perform Factory Reset immediately.
  • Warning!During working on this trick if accidentally your handset may have dead or faulted. We are not responsible for that please read our privacy policy.
Phonetolls
http://i.fixya.nethttp://i.fixya.nethttp://i.fixya.netwrite_tip-jtiacr1a5dvtxudcpg5eyczh-3-0.jpg
on Jun 24, 2015 | Cell Phones
I locked my samsung s5230 and i forgot the key what now?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 03, 2012 | Samsung SGH-S5230 Cell Phone
HOW DO YOU MOVE THE ARROW KEY ONCE YOU ARE IN THE MENU?
You use the button with the <> arrows to move through the menu selections. Use the menu key to select the function you want to change.
Below is an excerpt from the Acer manual. The manual can be found at http://www.retrevo.com/support/Acer-X203H-Monitors-manual/id/23224bh549/t/2/
Front Panel Controls
1.Power Switch:
To turn ON or OFF the power.
2.Power LED:
Lights up to indicate the power is turned ON.
3.Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY(EXIT
OSD menu).
2) When OSD menu is in off status, press this button to select scenario
mode.
4.Auto Adjust button / Exit:
1)When OSD menu is in active status, this button will act as EXIT-KEY (EXIT
OSD menu).
2)When OSD menu is in off status, press this button for 2 seconds to
activate the AutoAdjustment function.The Auto Adjustment function is
used to set the HPos, VPos, Clock and Focus.
5.< / >
Press < or > to select the desired function.Press < or > to change the
settings of the current function.
6.MENU / ENTER:
Activate OSD menu when OSD is OFF or activate/de-activate adjustment
function when OSD is ON.
Jul 02, 2011 | Acer X203H bd Monitor
I can not find a way to use the speaker phone. for the samsung s5230 tocco lite. When I get a call. It says press the hold key to use in call function. But how do I get to the speaker phone.
There is a 'Lock' (a lock mark on the key) key on the right edge of your phone.
While on call if you press that for 3 seconds you will see the in call functions of the phone, you will also see a 'speaker' icon.
Press the Speaker icon and then Yes on prompt. Your phones speaker function will be on.
Hope it helped.
Jun 17, 2010 | Samsung SGH-S5230 Cell Phone
My samsung gt-5230 response have turned very slow
u can format it through ur computer and update ur mobile from update center in run type cmd
format h: drive name of ur phone with: then asked is ur device ready then yes, yes then it will format ur phone then press enter
Mar 18, 2010 | Samsung Star GT-S5233 Cell Phone
I lost my puk code for samsung tocco lite GT S5230 on vodafone please help
this happens an awful lot, here is all about your problem. PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it. Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account. It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). More information on unlocking phones will be available here in the very near future. NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone. If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, use the links above to navigate your way to the specific PUK details for your mobile phone network operator.
Feb 06, 2010 | Lands Phones
Panasonic KX-TG2583. How do I change the time?
TIME/DATE ADJUSTMENT:
Press Function/Exit/Ch on the handset.
Press the up & down arrow keys until it points to 'program'
Press the Fwd/Edit > (yes key)
Press the up & down arrow keys until it points to 'tad program'
Press the Fwd/Edit > (yes key) the base unit will now display programming opitons.
Press '0'...'set time' is announced
Enter the time (hour & minute) using a 4-digit number
(Ex. To set 9:30 enter 0930)
Press * to select AM or PM
Press # repeatedly to set the day.
SELECTING THE NUMBER OF RINGS:
Press '2'...the current setting is displayed on the base unit
Press 0 or 2 or 7 to set the number of rings
(0='Toll Saver, 2=Two rings, 7=Seven rings)
Press Fwd/Edit (save key) a beep will sound
To return to normal mode press Function/Exit/Ch
I HOPE THIS HELPS! I copied it from my phone manual!
Best of luck!
Emma
Jul 22, 2009 | Panasonic GigaRange KX-TG5432 Cordless...
How to unlock my firefly
With ATT sim in phone, Power on & wait to initialize.
Then, press & hold the green key until the "Enter Pin Screen".
Then, press red button 5 times until the exit is displayed.
Then press & hold the phonebook key til the "unlock code screen".
Press the phonebook key once then. To enter the code you use the green & red keys to scroll to the proper numbers to enter 6 digit code.
You scroll to the proper number and press the phonebook key at the number you select until the entire code is entered.
Once done, you will scroll to the "done" and press the phonebook key once.
Jan 10, 2009 | FireFly Cellular Phone
Cell Phones Logo
128 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
