Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
Electric pto won't stay engaged on LT 1045
Cub cadet 1045 electric pto. Will engage but as soon as I start moving, it disengages (with PTO switch still in on position)
  • 1 more comment
  • Arthur Frerichs Jul 15, 2012
    This is not a lawn tractor; pto is mechanically engaged,no switch
  • Anonymous Mar 12, 2014
    when blades are engaged it will not stay engaged.
  • Anonymous Mar 16, 2014
    pto clutch engages as soon as ignition is turned to run
  • 130 Answers
You have a shortage or your clutch is going bad
Posted on Jul 18, 2009
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
PTO engages, but, keeps becoming disengaged on LT1042.
Cub Cadets have one of two types of PTOs. The most common is gear driven. The gear teeth of the PTO shaft are very small and thin. If the PTO is engaged without proper clutch action, the gear teeth grind together, trying to engage. A little wear on these gears will cause the surface of the gears to become beveled, and when the PTO comes under load, the beveled surfaces of the gear teeth force the gear lock to disengage. The only option is to replace the worn gears...
The second type of PTO drive is electric clutch. This is a disc type clutch that is engaged by energizing an electromagnet built into the clutch pack... any disruption of electrical power to the clutch pack while under load will cause the clutch to disengage and then possibly try to engage while under load and casues the clutch pack to slip and will overheat almost instantly...
Sep 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
PTO WONT WORK on myCub cadet ride on mower LT 1045
i seems you already found the cause its a electrical problem look at all the wires you have a loose connection some ware the wires also like to break where they go into the clutch
Jun 28, 2012 | Cub Cadet Garden
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Jul 24, 2009 | Mtd Garden
Cub cadet dead as a door nail
I have the same mower. The wires do need to be connected. It is a safety feature on the cubs. The engine will not start if the electric PTO is engaged. I just went into the garage, pulled the pto lever out to engage, pushed down brake, tried to start and it would not start. I suggest reattatching the wires and trying it. Hope this helps.
Apr 24, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
1,969 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
