Question about Acer Aspire 5100 Notebook
Slimtype dvd a ds8a1p ata device wont burn dvddl discs... also can it be made multi regional??
Slimtype DVD A DS8A2S ATA device won't burn
It is a common problem in most laptops, bui it seem's to happen more in ACER computers. See this page on this website, seems like there are plenty of post about the problem....
http://www.fixya.com/tags/slimtype_dvd_ds8a2s_ata_device_driver/pc_laptops/acer/page-3
Feb 12, 2013 | Acer Laptop Lcd Screen 15.6" For Aspire...
Please help, my ''Slimtype DVD A DS8A3S ATA Device '' won't work.
Click Start/My Computer then Right Click on the DvD Drive and select Properties. Click the Hardware Tab and double Click the Dvd drive or highlight it and click Properties. Click the DvD Region Tab and go down towards the bottom to change it by putting in a New Region.
May 01, 2012 | Computers & Internet
Slimtype dvd a ds8a1p ata device driver download
You may already have the driver on your laptop. Follow the following instructions to install them:
To solve the issue, you have to edit the windows registry
Click Start, then Run, type REGEDT32 and click OK.
Locate and then remove the following registry values:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}LowerFilters
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}UpperFilters
Close Registry Editor.
Reboot the system for the changes to take effect.
Hope this solves your problem.
Mar 21, 2011 | HP Compaq Presario V3000T Notebook
Slimtype DVD a Ds8a1p Ata Device Driver NOT FOUND IN MY NOTE BOOK AND NOT HAVING DRIVER IN CD
Go into your BIOS and see if the drive is recognized in there. If its not, then you'll need to turn off the laptop. Take out the drive from the system and then put the drive back into the system. Now go back into the BIOS and see if its recognized in there. If it is still not recognized then the drive is bad and would need to be replaced.
If the drive is recognized then go into windows into the device manager and see if the drive is there. If its not recognized properly then that means you might either have spyware or a virus on the computer. You can also try replacing the drive as well to make sure its not a drive problem.
Apr 19, 2010 | HP Computers & Internet
Slimtype dvd a ds8a1p wont burn disc
Do a CTRL+ALT+DELETE and open the Task Manager.
Burning requires a good and stable supply of resources from you computer. Close any unecessary application, processes and services which may be sucking up your available resources (I Highly recommend you get and install "The Ultimate Troubleshooter") to help you keep only relevant and necessary apps and services that are needed by your computer. This program anyalyzes, identifies and reports to you everything is finds running on your pc - explains in plain everyday English what it is, whether you need it or not and how to be rid of it if you dont. Then go to the following link, http://www.codecguide.com/download_kl.htm and install the latest codec pack to make sure your system is up-to-date. make sure your recording media is made for the specification of your dvd burner. I'll say it again, not all DVDs are created equal. The brand of discs you are trying to burn may not be compatible with your burners abilities. Disable any anti-spyware, malware, and virus protection software you have running. (temporarily) Then try again.
Finally, try burning at a lower speed... a lot of times, this alone is the only problem. STILL NOT WORKING?, run an optical disc lens cleaner which Walmart, Walgreens et. should have for minimal cost. If this doesn't work, then there is something more seriously wrong which will require a trip to a repair center
Aug 12, 2009 | Acer Aspire 5100 Notebook
Can't burn CDs/DVDs with the combo drive of my Acer Aspire 4315
OK you may want to tr changing the program you use to burn with. This will determine whether it is a hardware fault or a software fault. Try using http://cdburnerxp.se/ should help. I hope this helps. If it does could you please rate me.
Jun 24, 2009 | Acer Aspire 4315 Notebook
Acer 6920 dvd slimtype
Check out my fix for the 5100, may apply to you too. http://www.fixya.com/support/t1472132-acer_dvd_rom
Dec 20, 2008 | Acer Aspire 5100 Notebook
When trying to burn data to a dvd in nero this message appears unspecified recorder error f slimtype dvd a ds8a1p
In Nero you need to specify the correct drive/burner in the step before you get the "Burn" button.
Sep 03, 2008 | Computers & Internet
Acer 5100
Do you have a DVD Player software like WINDVD or InterDVD player?.
Oct 16, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
1,540 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
