Question about Garden
I have a ryobi 775r trimmer and need to replace the primer bulb and where the 3 hoses go
#1 Taper
  • 1041 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • 512 Answers
SOURCE: Ryobi 775r gas trimmer stalling when tilted
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Posted on Jul 17, 2009
canbruce75
  • 1776 Answers
SOURCE: fuel line routing on ryobi 775r
One line ( the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the lower port on the carburator. The second line goes from the fuel tank to the bottom fitting on the primer bulb. The third section goes from the top port on the primer bulb to the top port on the carburator. Hope this helps and best wishes.
Posted on Sep 01, 2009
Testimonial: "MAN I LOVE THIS WEBSITE,,IM VERY MECHANICLY INCLINED,BUT SOMETIMES GET STUCK,I FOUND THIS WEBSITE,ASKED,AND""POOF""-CANBRUCE75 HELPED ME,,THANK YOU."
rwvanlue
  • 486 Answers
SOURCE: primer bulb will not fill
There are aprox 5 sizes of primer bulbs that are common to trimmers, blowers, saws. You will need to be specific about carburetor brand and type when looking for a bulb. A small engine repair shop should have access to any of them.
Posted on Nov 25, 2009
  • 1126 Answers
SOURCE: how do I remove and replace a leaking primer bulb
http://odref.com/pdf/Ryobi/
see if you can find it here, since you didn't say which model you have....
Posted on Apr 01, 2010
Why is Ryobi trimmer primer bulb not drawing fuel?
Check the bulb to see if it is cracked, allowing air to get inside. If the bulb has lost its flexibility you might need to purchase and install a replacement bulb. It is a simple operation.
Sep 20, 2014 | Ryobi Garden
Where can I get a parts breakdown ( exploded view ) for a Ryobi 775R 16" string trimmer.
here's the link. http://www.partstree.com/parts/?lc=mtd&mn=775r+41AD775A034
Mar 17, 2013 | Garden
Replacing fuel line on trimmer model 775r - have have removed all the fuel lines and the bubble, but have forgotten the exact pattern to replacing the three fuel lines
Hi: I'm a new user to this forum. I recently had to repalse the 3 fuel lines on my ryobi model #775r. After researching the problem, I diagramed the flow of fuel in order to repace the fuel lines. If you require a copy of this diagram, send me an email . Regards, Tony
Oct 07, 2010 | Ryobi Garden
I have a 26cc ryobi weed trimmer--primer bulb will not draw fuel, but will draw fuel when I loosen the 2 screws that hold down the bulb
Possible issues:
1. Primer bulb or bottom assembly has crack or hole in it (needs replacing). See ebay for about $6.00
2. Fuel lines are not sealing to the primer nipples properly (cut line and re-attach if you have sufficient line available) otherwise; replace.
3. You may be somehow kinking the fuel lines when you clip it back in place due to fuel lines too short
My bet: #1 or #2. Good luck!
Sep 17, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My TP30 Ryobi weed eater turns and stays on while
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Jul 05, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Primer bulb will not fill on Ryobi 775R
Nov 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
Fuel line routing on ryobi 775r
Sep 01, 2009 | Ryobi 15" Electric Factory Reconditioned...
Jul 17, 2009 | Garden
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
254 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
