Question about Grundig Satellit 800 AM/FM/SW Radio
Need: Volume- and batt indic-levers for grundig satellit1400 (these are the buttons passing through the front)
I will try to get the spare parts here in holland. (Nedis Consumer Electronics e.g.).
Or in the worst case it could be possible to glue the things together.
Thank You for your assistance.
Guus(=August) Janssen
Posted on Jul 19, 2009
How do you change the input without the tv remote?
I don't have a grundig tv, but most tvs have the buttons to change input / channel /volume ect. hidden, normally at the back along one edge, but some times along the bottom. My LG has them on the right hand side when looking from the front. Hope this helps.
Oct 28, 2015 | Grundig GU22DVDPX 22 in. LCD TV
How do I tune a Grundig TV/DVD with no remote? Is it a combination of buttons on the front panel? Thanks
Get a pen and a piece of paper.
If I remember correctly, each button has a bizarre symbol next to it.
Draw the buttons on the paper and draw the symbol that appears beside each button.
With the TV on, press the first button and note what it does. Press it a second time to see if that progresses to something further or cancels the operation.
Repeat this for the other buttons.
I seem to remember a vertical green line appearing on Grundig sets which indicated that the tuning was activated. Look for buttons such as > or >> or < or << that suggest scanning for channels. Make sure you can pick up analogue TV signals in your area.
It also helps if you have a VCR or DVD recorder which is already tuned and you can tune the TV to that signal.
Jan 06, 2015 | Grundig 15 in. LCD TV/DVD Combo
Grundig Sattelit 800 radio-batt blinks w/new Duracell Alkakines from Costco(so they are fresh; good till 2024)
I have talked to the gentleman who designed this radio and he said that in order to correct this problem two pins on the inside of the front panel must be shorted while 6.2 volts dc is fed to the battery terminals. The whole radio must be disassembled to reach these pins, I have not been able to find a service manual to help me locate said pins. If anyone out there can find out where to get a service manual please contact majik2387@aol.com
Oct 20, 2014 | Grundig Satellit 800 AM/FM/SW Radio
The volume does not work on the benQ fp557s
Perform a damage check
1. physical observation of the device for damages
2. observe the volume lever or scroll button
possible reestablishment procedures
1. The volume could require increasing beacause was reduced.
2. locate the volume lever and tune the volume to listening capacity of suiatbility
3. A lever should be found on the side of the monitor with indications of tuning
Important notes
1. The monitor only send displays motion picture from a systme unit that also sends sound to output devices like speakers. make sure speakers are installed on the connection to the entire setup to acquire any listening experince.
Dec 05, 2010 | BenQ FP557-v2 15" 1024x768 White/Blk/Silv...
Grundig yacht boy 400 radio does not work with mains operations
I had the same problem. Examined the wire from the transformer,and found a break. Repair of the wire solved the problem. WLD
Mar 01, 2009 | Grundig YB 400PE AM/FM/SW Radio
G4000A
Once you turn the unit on, the battery indicator should disappear. Make sure the batteries are inserted correctly. With six AAs, I've put them in backwards on more than one occasion.
Hope this helps.
Mar 02, 2008 | Grundig G4000A FM/AM Radio
How to unlock a grundig t63-640?
Swich off tv from main swicher. Press i on remote control and hold it. Swicn on the tv from main swicher. On the screen should appear a service menu. Under decoder level with volume button from remote change from off to on. The same is with hotel mode for volume control. Exit the service menu by presing i on remote control and have a nice day!
Dec 27, 2007 | Grundig GF70-600 TV
Grundig Satellit 800 AM/FM/SW Radio Logo
93 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
