My laptop is msi m510c is off when turn on not boot i need bios file until uploading by usb flash please help me
  • 40 Answers
Please be more spacific in ur problem?
dragonslair2@hotmail.com
Posted on Jul 18, 2009
Motherboard BIOS update
Support For A55M P33 MSI USA Motherboard The world leader in motherboard... Use this page to download the BIOS update. At the bottom of the list is instructions on how to flash the BIOS
Sep 02, 2016 | MSI Computers & Internet
Battery overheating during recharge
It's very likely that your battery has malfunctioned. I would recommend buying a new one.
Jan 02, 2008 | MSI M510C Notebook
Please insert usb flash disk with BIOS file
You need to use a computer with Internet access, then go to the MSI WEB site to download the BIOS file for you model motherboard and then copy this BIOS file to an USB memory stick.
You and then insert this USB memory stick into your MSI computer and boot up the computer.
May 14, 2013 | MSI K8N Neo4-F Motherboard
Please insert usb flash disk with the BIOS file..
MSI Support > K9N6SGM-V > Main Support page,
http://www.msi.com/product/mb/K9N6SGM-V---K9N6PGM-FI---K9N6PGM-F.html
Hover your mouse on the Download tab.
(Overview / Specifications / Download / Support / etc)
Click on BIOS in the list
Regards,
joecoolvette
May 14, 2013 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Power failed during MSI P67A-C43 B3 bios update
Download the latest BIOS update from your computer manufacturer's website onto a USB flash drive. Refer to your user manual to obtain the manufacturer's website address. If the downloaded BIOS file is a zip archive, unzip the contents onto your USB flash drive. Jumper settings may need to be reconfigured on some motherboards to enter BIOS recovery mode. Most Intel-based motherboards have a jumper setting or switch near the on-board CMOS battery. The procedure for setting the jumpers will vary depending on your motherboard make and model, so refer to the motherboard documentation for specific instructions. Power on the computer and press "F2" to access the Setup Mode menu. If you are unable to access the setup menu, you will not be able to proceed with this repair. Take your computer to a repair shop, as the motherboard may need to be replaced. Use the arrow key to select "Boot Priority" or a similarly named field. Press the "Enter" key. Scroll down until "First boot priority" or "First boot drive" is selected and press "Enter." Select the USB flash drive as the first boot priority device. Press the "F10" key to save this setting and exit from the setup menu. Connect the USB flash drive to an open USB port on your computer. Then let your computer fully reboot. The USB flash drive should be detected and the BIOS should update automatically. When the update is complete, you may be prompted to restart your computer, or it may reboot automatically. If you are able to use your computer without any further problems of overheating or failure to recognize drives, your failed BIOS update has been resolved.
Apr 05, 2013 | MSI P67A-C43 B3 Desktop Motherboard -...
I need boot my computer from usb. what I need?
Generally, you need a few things:
1. The PC has to support booting from a USB flash/pen/key drive. There may be anywhere from 1-3 items to change in the BIOS settings to make this possible assuming your BIOS supports it. Some BIOS's may refer to your flash drive as a USB floppy or USB zip. Of course there are exceptions.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
Check out this comprehensive link to make a bootable USB / flash drive in your choice of several different Operating Systems.
I hope this helps and good luck. Please rate my reply. Thank you!
Apr 13, 2011 | Sony VAIO VGN-SR220J/B Laptop
Want to re-format MSI Notebook S420. Screen continuously shows windows 'loading' but never boots. I have the recovery CD but because the computer never actually starts, I'm not sure what to do with it!MSI
Hello megan_van
While your laptop is on, eject the optical drive and insert the recovery CD. Turn off your laptop via the power button, and turn it back on. The recovery CD should boot. Follow the on-screen instructions to do a clean install.
If the recovery CD doesn't boot, try holding down the C key after turning on your laptop. If it still doesn't boot, you will have to change the boot order in BIOS. Don't worry, this is easier than it sounds! Follow these instructions:
1. Turn on your laptop, and look for a message that says something like PRESS (USUALLY F2, F8, DEL, ETC.) TO ENTER SETUP / BIOS. Hit that key before the Windows logo appears.
2. After hitting the relevant key, you'll be taken to the BIOS setup utility. All BIOS utilities have different appearances, but it is basically a set of menus containing different settings for your laptops hardware. Somewhere on the screen (usually the bottom), is a set of instructions for navigation your way around the BIOS. Follow these instructions to navigate your way to the option for changing the boot order.
N.B. Since every BIOS setup utility is different, the specifics on where the boot order options are located varies from computer to computer. The menu option or configuration item might be called boot options, boot, boot order, etc. The boot order option may even be located in a general menu like advanced options, advanced BIOS features, other options, etc.
3. Once you've located it, use the navigational controls to place the optical drive above the hard drive (usually the +/- keys). To be certain that the recovery CD boots, it's probably best to move the optical drive to the top of this list.
4. Within the navigational controls, there is usually an option to SAVE & EXIT. Press this key. If there isn't, look for a menu option with the heading EXIT. A SETUP CONFIRMATION box will now usually appear asking you to confrm the changes you've made to the BIOS before exiting.
N.B. The SETUP CONFIRMATION box can sometimes be worded cryptically. Read the message carefully to be sure that you're saving your changes instead of exiting WITHOUT saving your changes!
Your computer should now restart automatically, and the recovery CD should now boot.
Hope this helps. If you require further assistance, please don't hesitate to ask.
ajblaj
Apr 28, 2010 | MSI MEGABOOK M510C Notebook
When I turn on my MSI M510C notebook - ''reboot and select proper
Your notebook does not see the proper boot files on your C drive. Many times the boot.ini has been corrupted.
You will need a Windows XP Install CD mounted in the CD Rom. When you boot the system you need to choose the CD as the boot device (if the notebbok does not do it by default) then typr R to enter the recovery console. Once you get the C: prompt you will need to create a new boot.ini file using the bootcfg command. See the following website for details in using the Recovery Console:
http://commandwindows.com/recovery.htm
Jun 15, 2009 | MSI M510C Notebook
When I turn on my MSI M510C notebook - I get this message "reboot and select proper boot device or insert boot media in selected boot device and press a key" and cannot do anything else. Can someone t
I've read this problem due to new hardware interferences with desktop computers, all they had to do is change a few pins around on the harddrives.. since this is a laptop, and is quite difficult and dodgy to access the hardware, the only other suggestion is to reinstall windows with a recovery disk, or windows CD-ROM.
Hope this helps :)
May 27, 2009 | MSI MEGABOOK M510C Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
