Question about NEC MultiSync MT850 Multimedia Projector
How do I align the color on an MT850
IMy MT805 has been great for years. Over the past two months however, the color alignment seems to be slipping further and further out of alignment. When I display anything, I can now clearly see a red image, a blue image and a green image, all across the screen. I need to adujst the colors so that they overlay each other(convergance I think) but no where can I find the prodedure to do so.
Can you help me?
  • 115 Answers
Re: How do I align the color on an MT850
pls check the board before the color wheel, as it is noticed that this problem comes with the main PCB Board.
Posted on Nov 19, 2007
0 characters
3 Points
Red haze at bottom of screen
Shut down the projector and allow time to cool before the lamp is taken out to be examined for any dis-coloration. If so the lamp needs to be replaced, try to test using a leased lamp to confirm Also check for shift in the alignment of the lamp settings and also the Lamp alignment.
Dec 15, 2011 | Epson PowerLite Home Cinema 8500UB...
Colors out of alignment Epson EMP 500
You LCD optical engine is out of alignment. This will require an authorized service center to make the adjustment or even replace the unit if necessary. There are 3rd party companies that offer this service, perhaps in your own town or nearby. You may want to weight the cost of repair to purchasing a newer unit.
Jun 04, 2009 | Epson EMP 5500 Multimedia Projector
PT L711U + all my black colors are blue
Your projector needs to be aligned and serviced, normal occurrence
after 6 years since service.
Apr 18, 2009 | Panasonic PT L711U Multimedia Projector
Slight RGB alignment problem
Please describe the allignment problem
Apr 19, 2008 | Philips ProScreen 4650 Multimedia...
Color shift
Hi there
There is unfortunatelly no section in the Service Manual to explain this sort of procedure.
You'll have to move the LCD panels one by one - millimeter by millimeter.
Mar 29, 2008 | InFocus LP290 1100 Lumen XGA LCD Projector...
Alignment (convergence) of color panels MT1050
I can assist you with that if you want. It is very tedious, but can be done. You need a cross hatch pattern generator or something with vertical and horizontal lines to lineup the LCD Panels again. Tricky little procedure if your not familiar with it. Let me know if i can assist you and hopefully save you agravation at the same time. Thanks Jay
Jan 12, 2008 | NEC MultiSync MT1050 Multimedia Projector
Color Alignment
reset the settings to factory default. then re-solder the fingers on the edge of the power supply board where it goes into the main board edge connector.
Nov 14, 2007 | InFocus Proxima DP6155 Multimedia...
Center adjust on Red gun is not aligning with B&G vert.
frist set blue and green than set red itwill shoew yu single chakall will be focous in single line than than gun will be allign horizontal if it will correct if itisnot comming than cathode problem.
Oct 06, 2007 | Sony VPH D50HTU Multimedia Projector
Color alignment is off
i also have the exact same problem. i picked up 3 of these used for my work and kept one at home. I knew one had issues and another had a burned out bulb and so on. I had a repair place to combine the two to make one good one. The repair man said that they had a real hard time keeping the color locked in alignment. It's not a physical alignment, its controlled by the board output and somehow the board can be adjusted. It was vague to me. After about a good couple of years of hard use the one at home is now doing the same. On one hand I want to fix it but I dont even have a plasma so I may go and spend $800-$1000 on a hi def DLP. At that price it won't be the best but it will rock this projector. that would be my advice rather than putting more money into this old model.
Aug 06, 2007 | Philips ProScreen 4600 Impact Multimedia...
Panasonic PT-LC56U Multiple pictures
Jan 17, 2007 | Panasonic (PT-LC56U-DEMO) Multimedia...
NEC MultiSync MT850 Multimedia Projector Logo
347 people viewed this question
Top NEC Multimedia Projectors Experts
Electro Med Services...
Are you a NEC Multimedia Projector Expert? Answer questions, earn points and help others
