Question about Casio Privia Keyboard Case
Turned on the Privia PX-575R and sound distorted, seems as if bender is in use intermittantly when noone is touching it- and almost like speakers are blown, but volume was never set very high.
    Novelist:
  • 133 Answers
You should probably check the bender controller and the master volume potentiometer, they might be dirty / oxydized, in such case, you need to either disassemble and clean them or replace them.
Also check for bad solder contacts on wires, connector pins and any of the components (e.g. voltage regulators, capacitors and/or other components).
Check all connectors for any dirt / oxydation on the pins and clean them if necessary.
Also check the main power switch (dirty contacts may result in erratic behaviour of the unit), and, if we're talking onboard speakers, see if the speaker protection mesh is somewhat loose, it may vibrate and cause the speakers to have dirty / distorted sound (you need to fix the mesh firmly in place to stop it from vibrating).
It could alse be a problem elsewhere in the unit (a bad resistor or capacitor, possibly some other component), these are just some of the things that may cause the unit to have dirty sound.
Hope you can make it sound well again.
regards
3rq8 (Triarcuate)
Posted on Aug 02, 2009
I connect the piano to midi and them the speakers stopped sounding, the phones plug too. how can i do the reset factory for the privia px 120?? thanks!
You don't need to reset factory.
You just need to change the setting of LOCAL CONTROL.
Lets start :::
While holding TONE / SETTING button,press key D#7 at 7th octave (highest octave on the right hand). Then release. That's all.
Then the sound must be heard..
Mar 11, 2015 | Casio PX120 Privia KEy ESSENTIALS BUNDLE
Is it possible to disable the speakers on my Casio Privia?
YES. Either plug in headphones into the headphone socket. There should be a switch on the back which disables the speakers as well. A simple ON/OFF switch for speakers
Aug 10, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
My Casio Privia PX-330BK Keyboard won't turn on.
Try checking your power cord. Perhaps someone stepped on it and it pulled out. It happened to me once. I thought something was terribly wrong with it. I was pretty embarrassed to find out that I'd just cut off power via cable... check your cords before worrying too much. If nothing seems to be wrong, take it in to the repair shop.
Sep 12, 2012 | Casio Privia Px330 Px-330 88 Key Digital...
How to fix loud key on Privia PX-830
I just fixed mine, it was making the loud sounds and had seemed to have lost the sensitivity. Take out all the screws on the outside, then the sides can come off. That gives access to the inside where you can take out a few more screws (easily seen) and open it all up. The keys themselves just snap in, so two small screwdrivers or strong fingernails can pop them back out. Clean the rubber contacts (they look like little sockets) with Q-tips and rubbing alcohol, then replace the keys. If you take out the white keys of an octave first, then the black keys (keeping them in order) it is a lot easier.
Jun 18, 2012 | Casio PX-830 BK Privia
My Privia PX-3 will run fine for about an hour. After that, for example, if I am playing a piano sound and want to switch to organ, I press the organ button and the LED shows that I have chosen the organ...
This problem is NOT DIY and will likely require a trip to the repair shop... One possibility is a static discharge... Try running it for hours with no clothes on that can produce a static buildup and see if it behaves. If so, take maeasures against static... no rubber soled shoes, no wool fabrics, gound yourself to something else before touching the unit...
Aug 16, 2011 | Casio PX3 Privia 88Key Digital Stage Piano
Is there a "Factory Reset" procedure for a Casio Privia PX-575R
Here is a link to the manual:http://ftp.casio.co.jp/pub/world_manual/emi/en/PX410R_e.pdf Page E-79 describes the procedure. Here is a link to their support page in case you don't have the CD that was bundeled with the keyboard:http://www.casio.com/support/
Oct 17, 2010 | Casio Privia Keyboard Case
Casio Privia PX-130, 8 months old: fluttering sound
If I were to venture an educated guess I would vote for failing filter caps in the power supply.
The power is likely collapsing under load of the speakers but headphones take much less drive.
If this has an external wall-wart power supply, you might try a new one IF the output is found to be under the rated voltage.
Internal power supply components are beyond those individuals that are not adept at electronics.
Jul 13, 2010 | Casio Music
Casio Privia PX-800: When using the sustain
Check if the cble frm the pedal MIGHT be flexing or pulling on the keyboard case when you use it. Such movement COULD vibrate the power connector causing your problem.
Make sure you have the right power supply for the unit as one with too large a hole for the power pin would be intermittent like this.
Jan 26, 2010 | Casio Privia Keyboard Case
Casio Privia Keyboard Case Logo
417 people viewed this question
Top Casio Music Experts
Ben Armstrong
Matthew Spark
Matthew Spark
Are you a Casio Music Expert? Answer questions, earn points and help others
