Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
I have a Yard machine by MTD, Model # zr700r. Ineed to replace the pull cord (to get it started) replaced. How do I get the plastic cord holder out of the shaft, to replace the cord?
You nnnd to un-screw the srews that attach the housing to the engine. There will be 4 more srews to un-screw to get to the cord
Posted on Aug 04, 2009
I have a model 600-699 1998 MTD 46in YARD MACHINE. Is it possible to check/add fluid to the trans axle?
I had a 1999 yard machine that did the same thing i had to replace the transmission it was still working when i sold it this year
Sep 04, 2017 | Mtd Garden
Repair lawn mower pull cord
Home Depot sells a replacement pull cord kit that has great instructions. My mower, however, had pop rivets holding the cover on the engine, so if yours does too, get a pop rivet tool with the correct size pop rivets before you start drilling out the old pop rivets.
Aug 07, 2014 | Mtd 22" Yard Machine Push Mower
Belt broke on my 12 inch mtd yard machine front tine tiller model 21a-250m000 how do i replace it. thank you for your help!
part # 754-04123 v-belt 1-888-656-7278 for parts pull off 4 bolt on bottom red cover to frame replace belt put cover back on
Feb 27, 2011 | Mtd Products Yard Machines 158CC Tiller
Handle on pull cord came off and cord went inside,
pull spark plug then pull cord see if fluid comrs out.if so check oil level,if over full see if it smells like gas if so you have a bad float in carb or dirt stuck in needle and seat in carb if all is good could have sheered flywheel key or if over head valve engine(has valve cover) valves may need to be adj or compression release mechanism in side engine broke. todays engines have very high compression and will not turn over without release. hupe this helpl
Aug 01, 2010 | Mtd Products Yard Machines 158CC Tiller
Pull start cord got pinched. Dumb me took off
Yes you can put the spring back in but it takes patience. Wind the spring inside the pully first. Then install the cord on the outside of the pully. Make sure you wind both in correct direction. You probably should replace the cord while you have it apart. The parts would be listed by the engine brand and model number, not by MTD. Probably a Briggs & Stratton engine? You can go to their web site :www.briggsandstratton.com to get part numbers. Or you can try a place like www.jackssmallengines.com
Jul 18, 2010 | Mtd 22" Yard Machine Push Mower
MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
Yard Machine won't start
Maybe the Spring is broken in the housing, that is assuming you are talking about a problem with the pull cord. Your question is kinda vaque. Submit more information !
Sep 13, 2009 | Mtd 22" Yard Machine Push Mower
I need to replace the pull cord on a 4hp, yard machine, 21",mower
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 20, 2009 | Mtd 22" Yard Machine Push Mower
Broken starter cord MTD Model 125-478R062
try this link.
http://www.smallenginesuppliers.com/shop/html/broken_starter_rope.html
you will want use size #4 or 4.5 starter rope. about 7 foot in length.
Mar 17, 2009 | Mtd 22" Yard Machine Push Mower
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
627 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
