Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Need a power supply - Mitsubishi WD-52525 52" Rear Projection HDTV
  • 668 Answers
Call Mitsubishi at 1800-553-7278 and see if it is still available or not. If not, see if they could refurbish the one you have.
Posted on Jul 18, 2009
Power supply
Any 450 Watt SMPS power supply is ok. Zebronic or Mercury retails around Rs.450 to 500. No need of costlier power supply like Corsair etc.
May 05, 2013 | MSI Custom 845 Ultra-c Ver:1 Motherboard...
Dell ATX(12v) power supply
The fact that it is made by Dell is irrelivent.
ATX is a standard and so are 20 and 24 pin motheroboard connectors.
You should find what you need by searching for: power supply unit on Wikipedia and Google.
Apr 08, 2010 | Dell 200W ATX Power Supply GX1 - GX110...
Need a part number for a 3310Le 110 vac power supply
Oops!
Generally the unit should have a part number attached to or printed on it somewhere. This is for the board with the power switch attached, it's called the power supply unit, so hopefully this is what you are looking for.
There seems to be two possible options, so you will need to determine which is the correct unit you need.
AZ23 0204 - Power Supply Unit: 100V (RoHs)
H555 5010 - Power Supply Unit - 120V
Nov 12, 2009 | Ricoh 3310LE Copier
I get no power at all to my computor. There is
The easiest and safest way is to purchase a power supply tester. Just unplug the power supply wireing harness from the motherboard and plug it into the tester. It gives led readouts. Its around five dollars. or just simply take it to a computer shop, most will check that for free
Aug 31, 2009 | Antec SP-400 400-Watt Power Supply
I need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Jan 30, 2009 | OEM Systems ATX P4 350 Watts Power Supply...
I just need a schematic for the ATXpower250 power supply.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm#atx-psu-pinouts
Jan 20, 2009 | StarTech.com (ATXPOWER250) 250-Watt Power...
NEED POWER SUPPLY FOR ELITEGHROUP L7VMM2 MOTHERBOARD
There is no specific power suppl that you need. The only differce is the wattage 300, 350 , 500 etc. Your motherboard will work with all types not to worry. The only reason you get a higher wattage power supply is if you plug in a lot of stuff. say you have 3 HDD and 2 CDROMS then you would need the 500 Watt power supply.
Jan 05, 2009 | E-Machines (ATX-300GT) (ATX30012) 300-Watt...
I need a new power supply
It's not more than 1yr and you would need to be the original purchaser with a receipt. MGE does not allow owernship transfers on warranties.
Nov 27, 2008 | MGE 400W Power Supply (QG) Power Supply
Need to get a new power supply for my samsung monitor
you first look the watt on the power supply and if same watt power supply is available then connect because power supply has overload protection it will not work also look the connecter is matching if not then purchase only original power supply dont chase the duplicate it will consume more money
Nov 20, 2008 | Computers & Internet
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
