Question about Relisys RLT-1500 15" LCD Monitor
Connecting sky box to to non scart reysis tv,via scart plug cable
This tv has no scart socket ,so i purchased an adapter kit.
the tv works fine but only in monochrome.
scart kit instructions say i need a 'composite lead'.
what is a composite lead?
  • 19 Answers
This lead is usually coloured yellow and looks like the red and white leads you use to connect the tv speaker OUT sockets to an amplifier or external speakers. The input on the tv should be coded yellow also.
Posted on Jul 18, 2009
Can a digibox work on a relisys rlt 1520
Posted on Jan 01, 2010
I have connecting TV link with coax cable from my sky box to my LG 50PH660V 50-inch Widescreen 1080p TV But I can not get the sky to come on my TV. as channel 68 is DTV and on my remote it says TV/RAD
If I understand your problem the Y splitter is a passive splitter which mean that the centre pins are connected via capacitors this will degrade the picture on one or both outlets, the Sky box should be connected via a scart or HDMI connection
Feb 03, 2015 | LG Televison & Video
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
Sep 26, 2017 | Televison & Video
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
Tv dvd and sky box
isn't there any manual/ book?
To connect TV to Sky Box VCR, connect the SCART lead from the AV1 socket on the TV to the TV SCART socket on the Sky Box. Connect another SCART lead from the AV2 socket on the TV to the AV1 socket on the DVD player and an RF cable from VCR to the aerial in socket on the TV.
Apr 27, 2013 | Televison & Video
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
When i plug my new tv into the sky box via a scart, the tv picture is distorted and a major buzzing noise is coming from the tv. sky have checked and said the box is fine. when u connect to another tv it...
Have you tried another scart lead? Also tried all of the tv scart sockets? Don't try and cure this by using an expensive upmarket scart lead, you'll just be wasting your money. The cheapest leads work just as well when the function correctly.
You could also try reversing your current lead by swapping the tv end to the Sky box and vice-versa, as there are many leads which cause feedback issues, and also a lot of "cut" leads (designed to prevent feedback looping) which must be fitted the correct way around. A "cut" lead is one where the wire to pin 19 at the tv end and to pin 20 at the video/Sky box end has been cut.
Note that scart leads MUST be fitted with the tv and Sky box switched off to avoid damage. Most people (including professional installers) regularly ignore this precaution though.
If all else fails then take the tv back and exchange it under the Sale of Goods Act; it's certainly not uncommon for new tv's to have faulty scart sockets.
If I've solved your problem then please take a moment to rate my answer. If not, then please report back with the make and model of TV and I'll try a more specific answer.
Jan 14, 2010 | Televison & Video
The sound isnt being played through my bush cht2dvd home theatre kit when im watching tv only when im watching a dvd its connected to my tv with a scart cable, Help please.
Hi Hoggy - do you still have the problem?
One way I found to solve the problem - if you have a Sky box (I actually have Sky+), connect the AV cable between the back of the Sky box and the Bush system. Then using the 'source' button on the front of the Bush - select AV1 (or AV2 depending on which AV sockets you plugged in to).
(Of course - will only work when watching a channel on the Sky box)
Steve (stevemweiner'at'gmail'dot'com)
Dec 25, 2009 | Audio Players & Recorders
How to set up Archos DVR Station but unsure how
Hi awillis98 this is Mike Houston of DISH Network, with the Archos DVRstation there will be a USB connection from the device to the DISH Networkreceiver, one the DISH receiver has recognized the external hard drive you willsee pop-ups on the screen that will walk you through the steps to configureyour Archos device. I will send a link to help with the setup for the externalhard drive. http://www.dishnetwork.com/SupportSection/setup-ehd
Apr 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
RECENTY PURCHASED SECOND HAND TV WITHOUT REMOTE OR HANDBOOK CANNOT SEEM TO SET UP MY SKY BOX TO IT ANY SUGGESTIONS?
Does the S/H TV have AV1 & AV2 settings and a scart socket? If so just connect the a scart lead from Sky box to TV and select AV1.
If you have no scart socket on the TV you need to connect a coaxial (aerial) cable from the sky box to TV and tune in to a channel. It is possible to tune in your sky remote if you have the TV code.
Please remember to rate this solution.
Oct 22, 2008 | Televison & Video
Relisys RLT-1500 15" LCD Monitor Logo
402 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
