Question about Panasonic NN-SD797S Microwave Oven
Panasonic Genius Prestige trips breaker
Our Panasonic Genius Prestige microwave (about 4 months of use) will trip the breaker whenever the start button is pressed.
It does not trip the breaker when sitting idle, opening/closing the door, or entering on the keypad. It only does it when the start button is pressed.
  • lakelandjim Jul 18, 2009
    Entered wrong model number. It is SN977S
Illeagle
  • 525 Answers
SOURCE: Microwave causes GFCI on another circuit to trip
You may have a shorted High voltage component. Possibly a recttifier,aka, diode. This should only be replaced by an experienced repairman as an extremely high voltage shock potential exists.
Posted on May 27, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Panasonic Genius Prestige Model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can order Panasonic parts here.
You can find an authorized Panasonic servicer here.
Posted on Sep 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: error code H-98
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
Posted on Dec 02, 2008
  • 140 Answers
SOURCE: I cannot open the door of my Panasonic NN-T543W microwave
Well do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door closed. Anyway that is where your problem is. Let me know if you need more hlep.
Posted on Feb 09, 2009
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
Panasonic Dimension 4 Genius problem
An internal fuse may have blown or the magnetron may have failed
Apr 09, 2013 | Panasonic Genius Prestige Nnsd997s -...
Samsung SMH9151 trips breaker when plugged in
You have a sort circuit inside, call a repairman or take to the repair shop
Aug 23, 2012 | Samsung SMH9151 Microwave Oven
GE microwave (Model JE2160SF03) trips breaker when door opened
Remove the control panel, take pictures of the door switch wiring while they are still connected to the door switches, then remove the door switch assembly. Have someone at the appliance store check each switch and repair the ones that are defective.
I purchased a switch for $7, reinstalled the door switch assembly and the microwave is working fine now.
Jul 02, 2012 | GE Microwave Ovens
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
Pushing the start button trips the breaker. All functions seems to work, fan, clock etc but it just started as soon as you push start it trips the breaker. Control panel/board seems fine no burn marks.
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Genius/Prestige/model.NN-P295SF
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Service manual below, troubleshoot with that. http://www.eserviceinfo.com/downloadsm/5734/PANASONIC_NN-K652.html
May 04, 2010 | Panasonic NN-P295SF Microwave Oven
My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
Feb 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Panasonic microwave model nn-sa616wx sn 58100747 it keeps triping the breaker after it operates for awhile we have taken a amp reading and it draws 17.2 amp.This is a new microwave.
Safety first, unplug your microwave from socket outlet.Needs to troubleshoots series of components using eliminating method to know which component(s) that causes breaker to trip off. It is obvious that a componet(s) "shorted out".Remove your fuse and replace it with resetable breaker tested.
Remove leads of the transformer output(secondary side). plug power cord run the microwave.If does not trip off the cct breaker change your transformer. do the same to capacitor lead, one after the other until you discover which component that shorted and cause your cct breaker to trip off.
Jul 24, 2008 | Panasonic Microwave Ovens
Breaker tripping
Make sure it is plugged into a 20 amp circuit. If it is in a kitchen it should be a 20amp breaker if it trips a 20 amp breaker it needs to be replaced. If it is a new house and you plug it in in the kitchen and it trips a 15 amp breaker then the house does not meet code. ref Article 210.52(B)(1) NEC
Jan 18, 2008 | Emerson MW8107WA Microwave Oven
Panasonic NN-SD797S Microwave Oven Logo
259 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
