Question about Garden
Line trimmer does not appear to have spark. How do you test a coil wire?
  • 130 Answers
You can connect a new spark plug to the spark plug wire and ground the spark end to the motor you should see a spark if not ajust coil to 010. from flywheel if no spark after that coil is bad get new coil
Posted on Jul 18, 2009
How to check ignition coil with ohm meter
The only way I know how to test a coil is to take the small wire that hooks into the tab on the coil off and then use a spark tester, this way you isolate the problem to either the spark plug or the coil. unplugging the small wire will eliminate the coil being grounded out by the switch.
Jun 05, 2014 | Troy Bilt Tb70ss Gas Trimmer
Broken spark plug wire eater weedeater
If the wire runs all the way to the inside of the coil pack, then you will have to replace the whole coil unit.
George
Oct 24, 2013 | Craftsman 25cc Gas Line Trimmer
No spark crafsman 25cc 17
remove the cover from the engine to see the coil remove the small wires from the coil and spin it over if still no spark replace the coil
Aug 20, 2012 | Craftsman 25cc Gas Line Trimmer
I have a craftsman 32cc weedwhacker trimmer and its brand new and it hasnt started from day one it isnt getting any spark at all
If you have spark problems, remove the wire and then remove the plug, reattach the wire and ground the plug to the engine and pull the string, you should see arc and hear it pop, if not, take the plug to another piece of equipment and remove that equipment's plug wire and attach it to the plug from the weed ******* and then ground it and test it. If still no spark, then plug bad, if plug then the weed ******* has a problem with the spark plug wire or the ignition coil.
If you have spark at first test, then the problem with the weed ******* is somewhere else.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
Turn but not start
if you have spark, then the carberator is plugged, replace it. Pull the spark plug, ground it to the engine, pull rope, whatch plug for spark. if no spark, remove kill switch wire from coil. pull rope agin, if you have spark, kill switch is bad. if stil no spark, you have bad coil.
Sep 24, 2010 | Craftsman 25cc Gas Line Trimmer
Eager ****** gas line trimmer will not start no spark at plug
The best test for an ignition coil is removing the wires going to the kill switch at the coil. Most small engines will run with the kill circuit open & stop when you ground it. If you disconnect the kill wire & you have no spark, than it's a coil.. If you do have spark, check the switch & kill wire for a possible short.
Sep 21, 2010 | Garden
No Spark - Husqvarna 125R Trimmer
Check the wire that goes to the "OFF" button. See if it is by chance loose or cracked allowing a short. Beyond that, it would probably be the coil, but I would lean towards some type of a short, especially if you know the plug is OK.
Jan 09, 2010 | Husqvarna 28cc Gas Line Trimmer
Stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
Sep 17, 2009 | Garden
Craftsman flipover head string trimmer. Will not start. No spark.
could be coil also could be a fouled,dirty flywheel,check coil wire
Aug 25, 2009 | Craftsman 25cc Gas Line Trimmer
No spark,craftsman string trimmer
  1. Remove the flywheel cover and pull the ground wire off of the off of the coil...
  2. Check for spark...
  • If you now have spark you have a "short to ground" some where in the in the wiring
  • If you still don't have any spark you'll need to replace the coil
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
484 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
