Question about Microsoft Natural Keyboard PRO. Two USB Ports 19 hot keys for instant access Supports Win XP 2000 ME... (B6100002RETAIL)
Wireless keyboard my roommates keyboard had soda spilled on it now it is messed up how do we fix
  • MICK FIXIT May 11, 2010
    THATS THE ONLY THING YOU CAN DO THEY DONE A TEST ON THE GADGRT SHOW AND BASICLY TAKE IT APART DRY IT OUT COMPLETY
    Problem Solver:
  • 17 Answers
Its very easy just use a philips screwdriver undo all screws, carfully separte the keyboard then clean inside if it is still wet then use kitchen towel or a clothe to absorb any moisture.  If its already dried out then use
 a damp cloth to clean then kitchen towel over all u  have cleaned.
reasemble and test if fails then a new keyboard is needed check link
http://www.microdirect.co.uk/productlister.aspx?n=8,35&n=137
Posted on Nov 19, 2007
I spilled soda on my Macbook Air yesterday. Today, two of the buttons are jammed together. What do to? Help!
You have to be gentle but you can use a tech sized screwdriver and pull the key off. From there you can clean if up a bit more thoroughly.
Feb 28, 2015 | Apple MacBook Air
Spilled drink keyboard
ifixit dot com sells the screwdriver you need for the bottom plate (and pics of how to take it apart)
Aug 26, 2014 | Apple MacBook Air
Samsung RV520. Spilled soda under it cleaned up let dry was working for a few minutes at a time. Now not working at all. Can it be fixed or do I have to replace it?
The way you can test it, you must remove the keyboard and the see if the laptop turns on without the keyboard. if it dose you will have to put in a new keyboard.
Dec 06, 2013 | Computers & Internet
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
Spilled soda on my laptop keyboard
It is impossible to clean and fix the keyboard. The best solution is to replace the keyboard.
Try this WEB site for a possible replacement.
Keyboard replacement, LCD screens for mobile phones, Ipods and computer equipment. http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Dec 01, 2012 | Computers & Internet
Spilled soda on toshiba laptop m505, keyboard is not working. keys don't stick anymore but not working. what do you recommend to fix it?
You need a new keyboard. The sugar in the soda caused the damage and will further corrode the keyboard.
I would also recommend that you clean the area where the soda may have spilled to on the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 14, 2011 | Toshiba Satellite A135-S4527 Notebook
Left button recently requires "extra" effort to make it work...any explanation?
Have you spilled liquid such as coffee or soda into the mouse? If not, the micro switch is starting to fail under the button.
Jul 18, 2009 | Microsoft Wireless IntelliMouse Explorer
Spill soda on my laptop keyboard
It is likely the only problem is that the soda is causing the keys to stick. There is probably no damage to any other internal components. Usually, laptop keyboards have a metal-based frame/tray that will protect the internal components from minor spills.
If you want to get rid of the cracking sound, you'll need to purchase a replacement keyboard from the laptop manufacturer or another source such as eBay, and then remove the sticky keyboard and replace it with the newly purchased one.
Mar 23, 2009 | Toshiba Satellite L305D-S5895 Notebook
Spilled soda on it, screen doesn't work now...
boot the laptop up, plug in monitor
press anf hold fn key on keyboard, now tap f4, keep hitting f4 until both monitor screen and laptop screen come on
Feb 05, 2009 | Dell Inspiron 1501 Notebook
Sharp calculator
I had the same problem happen to me. What I did was carefully take the calculator apart using a T-10 Torx screwdriver to remove the back cover. I then used a compressed air can and blew air into all the crevices and holes in the calculator. I was able to dry almost all of the soda the spilled, however some of the soda dried and turned into somewhat of a sticky mess. I was able to carefully wipe the sticky parts clean with a tissue. After doing all of that my calculator worked perfect.
Nov 15, 2008 | Texas Instruments TI-84 Plus Silver...
Computers & Internet Logo
274 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
