I have a short somewhere in my desktop that is taking out my PSU's. The last time I moved some wires just a little bit and it went out. I need to know how to locate the short so I can rebuild the system with no more problems. I am not going to do any trial and error type troubleshooting since I am losing PSU's each time.
  • seth veloso Jul 19, 2009
    thanks for the response and sound advise, I traced the problem to a bad mobo, if i unplugged the psu and plugged it back it, it would work again. The first one is shot I can hear it.
    seth
    President:
  • 1,179 Answers
Check the offsets between your motherboard & case. Make sure no part of your motherboard is touching the case. An offset may have vibrated loose. Also check the washers around your motherboard mounting screws to see if one has cracked or broken. Check your psu cables as well as all other cabling to make sure none is cracked or frayed. Last but not least check the exposed pins on your mb to see if any are bent over or broken & maybe touching. This is time consuming but it beats repacing a psu everytime you use the system. Hope this helps.
Posted on Jul 19, 2009
Fans come on 4a second and shut off wont boot
Thank You For Posting
The "fan twitch" you're seeing is a nearly certain proof there is a short circuit somewhere. It could be the PSU, it could the the motherboard, or anything directly connected to either or both of them.
You need to reduce your machine to PSU + motherboard (out of the case/on the table) + CPU (with heatsink of course) + one stick of RAM + video card (if there is no integrated graphics). Reset CMOS, re-seat your CPU, cleaning the old and applying a new coat of thermal paste as needed, re-seat RAM and a video card if needed, then try turning the machine on. You can use a screwdriver head to short the power-on pins on the front panel pinout of the motherboard, if it doesn't have a dedicated power-on button on it.
If it still just twitches the CPU heatsink fan, remove graphics card (if you used one), connect a speaker to the front panel pinout (if the board doesn't have an integrated speaker/buzzer on it) and listen for an error code. If you didn't need a video card (have onboard/integrated), then remove the RAM stick and listen for an error code, if the machine even starts.
Reducing this to PSU + motherboard + CPU problem, means you should try a different PSU. If the machine still doesn't spin the fan, your motherboard is shorted somewhere, probably the VRM.
Thank You For Using Flixya and expected to see again
Jun 03, 2014 | HP Compaq Presario SR5050NX PC Desktop
Why wont my compaq pressario sr5522uk wont turn on
See if this link
https://ssl.www8.hp.com/uk/en/hp-search/search-results.html?ajaxpage=1#/page=1&/cat=Support%20%26%20Drivers&/cc=uk&/lang=en&/qt=COMPAQ%20PRESARIO%20SR5522UK
and from that page, this
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=65607&tmp_task=solveCategory&cc=uk&dlc=en&jumpid=reg_r1002_uken_c-001_title_r0001&lc=en&product=3755413
You need to say exactly what the circumstances and what happened during power failure and exactly what happening when you power up now. Take the side panel off and look inside when you power up. Do the fans spin ? You should disconnect everything and reconnect only the mouse k/b and monitor. Also turn off your PSU using switch on it (if present) and unplug from the mains, and try again after a bit (say, 8 hours). Which lights come on the front panel ? Power ? Hard disk activity ? Does it try the CD/DVD/floppy ?
There used to be (it might till be there somewhere) a page describing the what the behavior of the lights on the PSU meant.
Short of anything visibly obvious inside the case and no other symptoms (as you describe) I'd try swapping the PSU for a known good one but it really might be almost anything. Your HD might have been caught in the middle of doing something making that faulty. Fault finding is mostly educated guesswork then random chance. Maybe in the worst case your m/b is dead.
20.December.2014
May 26, 2014 | Compaq Presario 5000 PC Desktop
Asus P5GC-MX/1333 system wont boot up, motherboard light on (blinking), fans on PSU not working, fan on motherboard not working, is that a sign PSU went bad? (it was OK a few days ago)
yes
it can be problem wth psu hence insert a wire in green socket and another in black socket of psu and this will short and psu fan will rotate. if psu fan rotates then you need to check the voltage supplies of the psu.
Apr 01, 2014 | ASUS Computers & Internet
I have a 99 ram 4x4 slt laramie dome lights cargo light and map lights dont work, replaced #12 fuse 10amp under the black fuse keeper thingy on the drivers side but it keeps blowing it some times it lasts...
Classic symptoms of a frayed wire carrying current somewhere in the circuit, but touching metal, bare metal against bare hot wire: instant SHORT! Maybe a little spark there. Fortunately for you, you have a 10 amp fuse in that circuit which blows, and keeps the wiring from melting, and maybe starting a fire somewhere in your vehicle. If the fuse doesn't blow right away, the bare wire has moved away from contact with metal, but eventually, with enough movement it gets back into position and shorts again.
Enlightening, but not very helpful, eh? I'm afraid that's the way it is, Richard. Shorts like that can be very difficult to trace and find, without time and patience, a decent understanding of auto electrical systems, a wiring diagram for your Laramie, and knowing just what circuits that fuse protects.
If you have the owner's manual, it should list the circuits for that #12 fuse. I'd start with the dome lights, and remember, the door switches are part of that circuit. Good luck.
Mar 19, 2012 | 1999 Dodge Ram
Just tried to install a new ATA DVD drive in my HP A1240a desktop. would not powerup. went back to original configuration and still will not power up. no fans turn. no light on front button. is there a...
Check the I/O switch on the back of the PSU, make sure it's set to I.
Check the mobo and CPU power connectors from your PSU to the motherboard.
Push in the Reset button (in front of case) first, then try Power button (some motherboards want the reset pushed first before re-booting after being completely powered down.)
-J
Sep 25, 2009 | HP Computers & Internet
Need to find a short
Sounds like you may have lost your BIOS setup. Go inand setup for default and see what happens
Jul 18, 2009 | Computers & Internet
Green light blinking
posible the PSU has failed or have a short somewhere inside case/MB/hardware
Jul 01, 2009 | HP Pavilion a620n (PC028A) PC Desktop
No power
press the num lock key light .....
if the light doesn't blink Ram is the fault...
Remove the Ram and Take white Eraser and clean Ram pins and
fix the ram .. Mostly it will work....
Mar 11, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
HP LaserJet 3330
Remove the small glass pane of the left side of the scanner bed. You onlt need to remove one screw. Push the driver belt which will move the scanner to the left. It can be a little tricky to move the scanner the last little bit so you may need needle nose pliers or someone with a hook (I used a fork) to pull the scanner last little bit. Once the scanner is in the open spot where you removed the glass panel, simple take a q-tip and clean the mirror.
I did this and my machine is working just fine.
Nov 13, 2007 | HP LaserJet 3330 All-In-One Printer
29 people viewed this question
k24674
