Question about Sony FD Trinitron WEGA KV-36FV27 36" TV
My nephew plugged his xbox into the back of my Sony Wega 36 and smoke came out of the back of the TV. The set comes on and the tube works but there is no signal from any input. Can this be fixed?
  • Sony Master
  • 8,457 Answers
Yes,u probally have brown capacitors,in the video board.
Posted on Dec 19, 2009
Dead set. Smoke came over the TV.
The smoke is usually came from burnt resistor cause of short circuit or shorted parts inside..
Try to open the back cover of your TV and look at the resistor burnt..and replace it..also try to find shorted parts connected to burnt resistor or behind it..
Oct 22, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trinitron wega kv-36fs200 36' tv is missing green color
sounds like a major fault with the line output transformer/power board. if no green on screen, tube is on it's last legs. Advise to scrap, not to repair, cost in excess of £200
Oct 23, 2009 | Televison & Video
The red and green lights on my Sony KF-42SX300 keep flashing, and the TV will not switch on. It was working fine earlier, the lamp light also comes on, but not all the time, it has noly just started doing...
I would take the Lamp out and see if it is shattered. It is not unusual for them to fail suddenly. If it is shattered, you can contact Sony at 1800-222-SONY and order one.
I hope this helps
Skyassoc
Aug 28, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
I have a 2001 sony wega 36 inches and the channels
If you are comfortable with working inside the set where there are potentially dangerous high voltages present, you can probably fix this easily. Open up the back and remove it. Plug the set back in and turn it on. In the lower right hand side will be the flyback transformer (large red wire coming out of the top and going to the side of the picture tube). DO NOT TOUCH IT!!! On the back of the flyback should be 2 "knobs". One will be marked screen and the other focus. Carefully adjust the focus until the picture is clear. When you do this, go beyond the clear point and work the control back and forth a few times before settling in to the focused spot.
That should resolve the problem.
Dan
Apr 07, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
My 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Feb 17, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Best setup for Xbox 360 for Sony 32" Tube WEGA tv
Hi, Not sure whether you are kidding or not. You don't mention the tv model so I will try to help using a KV-32FS100 as an example. You really only have 2 choices assuming you have a current model xbox 360. The component cable that comes with the xbox has 6 connectors, a green, blue, red, yellow on one part and a white and red on the other part. On the back of the tv below and to the right of the s video connector are inputs labeled Y, Pb and Pr and are colored Y is green Pb is Blue and Pr is red if they aren't colored that is the correct order. Don't connect the yellow to anything. The red and white on the other part of the cable go directly to the right of these connections. It will say audio and L and R they should also be colored but if not white is L and red is R. There is also a small switch at the xbox end of the cablewhich you need to slide to HDTV. Once you are powered up don't forget to enter the setup menu on the xbox and select the settings for your tv. Again without knowing the model most wega tvs limit the component input to 480p which was the limit of a dvd. I hope this is helps.
Jan 28, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
Dec 27, 2008 | Sony KV-32XBR85 TV
2001 sony wega 36" tv tube
If you turn the color all the way off the picture should have good black and white if not the crt is at fault. If it is good it could be the jungle ic or the possibly the red color driver in the crt board
Apr 06, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony Trinitron TV will not turn on
First thing that comes to mind is that the horizontal driver transformer has bad solder connections on the primary and the secondary windings. Also a set this old could also have a defective regulator IC if you dont know wht m saying , b=est thing to do is find out how much an estimate is then go back to best buy and see what a new set cost cause man you got your moneys worth outa this one for sure!!!!! Good Luck
May 02, 2006 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony FD Trinitron WEGA KV-36FV27 36" TV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
