ENet Management WLAN not connecting; after successfully connecting for 2 months...why has it stopped connecting and stopped detecting wireless networks?
My WLAN says disconnected and it does not find my wireless says windows Cannot find any networks but my itouch working how do I get my laptop to connect again oh I restored to factory settings how do I get...
If you installed the adapter drivers you could have installed also the producers software.
In producers software can happen there is also theyr propretary software for Wlan management. The Windows Wlan management software cannot work if another Wlan management software is installed.
You have two option:
option one is to use producers software to scan wireless network and connect to your network via this software.
Check the box to instruct the software to use only Windows wireless management software and connect via Windows native software to your wireless lan.
Let me know if you solved your problem
Mar 30, 2011 | Acer Computers & Internet
How do i check if my acer travelmate 4230 has a bluetooth module ?
Hi, You need to Acer eNET Management, the empowering Technology,
using Acer eLock Management and Acer eRecovery Management, you must initialise the Empowering Technology password. Right-click on the Empowering Technology toolbar and select "Password Setup" this will enable you to do so. If you have not initialized the Empowering Technology password and run Acer eLock Management or Acer eRecovery Management, you must create it.
Acer eNet Management this will assist you to quickly connect to both wired and wireless networks. to access this utility, select "Acer eNet Management" from the Empowering Technology toolbar or
run the program from the Acer Empowering Technology program group in Start menu.
This should resolve your issue
Apr 06, 2010 | Acer TravelMate 4230-6499 Notebook
How do i enable my acere enet management, its saying that its off..... its a Acer 5315
This is one for anyone familiar with the Acer eNet Management software. It consistently connects to wireless networks besides my own. The "Auto" profile is unchangeable, so I created another profile, and put my network in the "WLAN perferred list", but everytime the computer restarts, it selects the "Auto" profile instead of my own, and connects somewhere else. Searching on other help forums, the solution I've found has pretty much been to ditch Acer eNet Management and use another managment software, like the one build into Windows. I don't mind doing this, but I simply can't fathom that the people who developed this software didn't include an option to change the default profile. If so, I think I've just lost all faith in my fellow software developers. But alas, after hours of googling and reading manuals, this seems to be just the case.
The only info I can find is that it "automatically uses the best settings (changes profile I assume) based on location". This would seem to indicate there somewhere there exists a setting mapping certain locations to profiles. How the heck its supposed to know what location you are in (home, office, etc) without you telling it (scan Wifi networks maybe?) is odd, but even so, since this particular computer never moves, there has to be a way to have it always use a certain profile, even it means I have to map this profile to a "location". These obviously are not the "best" settings for me since it connects to my neighbours unsecured wireless, instead of my secured wireless. And it doesn't just sometimes not select my connection, it ALWAYS doesn't select my connection, even though it's 5 bars vs 3 on the other connection.
I also went into "Settings" in eNet Management and deselected the "Switch Networks Automatically" and "Allow Acer eNet Management to connect automatically to an open wireless network" (which are profile independent so they stay deselected) but IT STILL DOES.
I think I just needed to get that off my chest, but if anyone has other solutions besides disabling eNet Management, is it possible to control what profile it selects on boot?
Thanks very much!
Oct 30, 2009 | Acer Aspire 7520-5757 Notebook
My internet is not connecting & the acer enet
Acer enet management can cause conflicts with the normal windows connection service.
try disabling acer enet management and then attempting to connect to the internet.
Right click on the enet management icon on your toolbar and then click disable, and then try to connect to the internet using windows.
Oct 29, 2009 | Acer Computers & Internet
Keep losing internet connection.
The simplest solution is usually to switch from eNet's management to Windows' Wireless Configuration Utility. Other than that, solving the problem would need much more detail, such as the router type, the distances involved, the router's antenna setup, the other equipment in the are and any intervening obstacles.
Apr 22, 2009 | Acer Computers & Internet
Recently Updated: Wireless Nolonger works Properly
Hi dear install the service park 3
Thank you
Imran
Pls rank as possible have nice day
Apr 12, 2009 | Computers & Internet
Enet management problem
Sounds like you are having problems connecting to your wireless network?
If so, disable eNet Management and reboot. If problem is still there, reboot your router. If problem is still there, update router firmware.
If you can see the networks but not connect to them, it is a router problem.
Feb 09, 2009 | Microsoft Office Outlook 2003 for PC
Notebook won't connect to network
1) Verify if Wi-Fi WLAN interface of your notebook is OK.
1a) Check whether HW switch is ON and the wireless system service is running.
1b) Switch on the WLAN Access Point (router) SSID broadcasting.
1c) Scan WLAN networks by the notebook. Can you see your home WLAN? If not, there is HW or SW problem in your wireless adapter probably. If WLAN is visible, continue by next steps.
2) Remove all WLAN security on both sides (AP and notebook): Authentication = none/open, encrytption = none.
3) Activate DHCP server in the router and set the dynamic IP assigning on WLAN notebook interface.
4) Select your home WLAN SSID in the list and try to connect.
5) Wait and check status. Is WLAN connected? Does obtain the notebook an IP address?
6) In success case set the WLAN security.
Dec 20, 2008 | Computers & Internet
My enet management in acer empowering technology is not working
If you do not know how to configure a profile and auto doesn't fly then you can just uninstall the Acer proprietary Empowerment and let Windows manage your wireless connection. This is Acer-specific technology so if you want to use it then research the Acer manual for setting up profiles. ~Steve
Sep 08, 2008 | Computers & Internet
Do you have "What do you suggest I do to stop the alternating messages? It's almost as annoying as popups." I get an alternating popup (actually fade in fade out) message. the alternating message says "Acer eNet Management Internet Disconnected" Here is my solution!!! :)
First 'Right-click on task bar', TASK BAR IS AT THE BOTTOM OF YOUR SCREEN' then click on 'Properties'. Click on 'Notification Area', Click on 'Customize', Look for WLAN(disconnected), Click on it and choose 'HIDE', Click 'OK', then click 'APPLY', then click 'OK' and now you have no more annoying message. TOO EASY MATE ;)
Jul 25, 2008 | Microsoft Office Outlook 2003 for PC
Computers & Internet Logo
David Payne
David Payne
