Question about Acer Aspire 9500 Notebook
Starts at 54Mbps but falls to soon 1Mbps
Starts at 54Mbps, everything running smoothly, but falls to 1Mbps and too slow to download anything.
Lan works OK
Why is my wireless connection being so slow?
Check you have your cable modem plugged in to the WAN port, not the LAN port on the router.
The manual s here
http://www.downloads.netgear.com/files/GDC/WNDR3400V3/WNDR3400v3_UM_8FEB2013.pdf
If it is still a problem consult your ISP about the set up.
Apr 27, 2014 | NetGear WNDR3400 N600 Wireless Dual Band...
RE: 3G wireless broadband. my computer runs slow when i download videos. could my 3G stick beweak or is it my server which is Mobi PCS be at fault?
3G is not a very fast way to watch video. The bandwidth is not wide enough. The standard bandwidth for 802.1 g is 54mbps the usually obtained bandwidth is in the region of 1mbps. This speed is good enough for a small screen resolution video. But for a larger screen resolution it is no way near fast enough. It is not your stick or your computer. it is just that you are using the wrong data transfer system for the job.
Feb 05, 2012 | Dell Latitude D620 Notebook
Vizio xr100 connection slow
This router has a theoretical max throughput of 54Mbps which realistically well get you about 26-30Mbps between your computer and the router. Now if you have more than one person using it this will slow your speed down, also the further away from the router you are the more the speed degrades to a point of about 1Mbps at around 120 ft give or take depending upon router placement and anything solid in between you and the router. You also have to take into account that this router operates in the same frequency range as cordless phones, microwaves and anyone else's wireless network close to your own. Now compound this with the limitation of your ISP take your ISP's advertised speed and cut it in half this is about what you can expect in speed. You have some options, You can run an ethernet cable from computer to router to eliminate all the wireless problems, you can move the router to a more central location in your house/office or get a wireless extender to increase the signal, you can invest in a MIMO n router which overcomes a lot of the problems with g routers. Also you can invest in a better internet connection. Hope this helps a bit, let me know if you have questions. Also to test your speed you can visit speedtest.net
Jan 08, 2012 | Vizio XWR100 Wireless Router
My down load is very slow
Hi,just check your speed from here http://www.scanmyspeed.com/ and if still your speed continues to be slow contact your provider.
Mar 08, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
What can i do to fix the lag on youtube?
If all websites load slowly - check your internet connection speed at speedtest.net - for normal youtube video watching >2Mbps download speed is sufficient. The solution is changing the video quality on the youtube screen to least possible 360p or even 240p to run smoothly on 1Mbps.
If only youtube site opens slowly, while other sites open quickly - your internet provider might be cheating in order to save usage of bandwidth (video sites take 50-90% of the total internet bandwidth). Make a complaint to your internet provider, supervising authorities, or even change for another - better internet provider
Feb 21, 2011 | YouTube Videos
>>I'm having problem with my internet connection,\r\n-I already called my internet service provider to fix the problem but they told me that the problem is with the router, Directly connected to the...
the problem with wireless routers is that they only will put out little more than 1mbps it may say 54mbps, but it'll usually only download at about 1 mbps, ive found it frustrating myself, but thats all the firmware in those will allow, ive tried to upgrade mine, but still the same, there isnt a fix that i'm aware of, wireless "N" maybe different but i doubt it, sending that much information wirelessly creates alot of heat,
Sep 19, 2010 | Linksys Wireless-G WRT54GL Router
Ethernet works wirelss is very slow
Most of the wireless adapters connect at a speed of 54mbps max, while wired lan connection adaptors (LAN adapter/cable) works at max of 100/1000mbps. hence use a cable to connect the PC to make it faster than using wireless.
Aug 17, 2009 | 2wire 1800HG Router (RG1800HG00)
Simple broadband question plzzzzz awnser
lol the cost of your internet will only change if you call them up and change your plan. if you go out and buy a new modem it will go the speed of the modem....so basically having a broadband connection with a 1mbps modem is like trying to force an elephant through a mouse hole....lol so to answer your question straight you get a new modem you'll get faster internet....have fun
Feb 06, 2009 | Monster Cable (109611)
Is there any Windows Vista Driver for the ZIO 802.11g 54Mbps Wireless LAN PCI Card???? I can not find any driver specifically for Vista!
for a good quality solution you might need to ask a premium question its worth it you get answers in seconds and for a bit more you can talk live to the person.
Dec 30, 2008 | Computers & Internet
Lan wireless card
thats the 1mbps is the adsl down load speed or the transfer speed ur service provider provides u. that from exchange to router. 54 mbps is the transfer of data rate  bw ur router and computer
Jul 31, 2008 | Computers & Internet
Acer Aspire 9500 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
