Question about Refrigerators
Right hand door pops open when closing left hand door
  • Refrigerators Master
  • 1,606 Answers
The dool seal is not sealing completely on your fridge door . Maybe pulled in corner , split somewhere . If looks ok , then magnetic portion is not sealing against cabinet somewhere . Once you find the area , use a hairdryer to soften the rubber while door closed and it will pull itself down due to the magnet .
Posted on Jul 19, 2009
My door will not open on my washer and it will not start the wash
try pulling the handle with youre left hand kind of hard & at same time push in on door with right hand close to handle work it back & forth if that don't work try jerking on handle with left hand with right one on machine gasket maybe stuck or handle broke inside door hope u luck Nick
Feb 12, 2015 | Washing Machines
Tappan gas range oven door hinge is binding
What is the model number of the unit?
Nov 29, 2012 | Kitchen Ranges
Fridge door doesn't stay open
make sure frige is level left to right. then make back slightly lower than front. while making sure it is level left to right.
Apr 19, 2012 | Refrigerators
My driver side door makes 2 popping noises when I open and close it. o5 chevy equinox. Noise is coming from black arm joining door to car.
Front Left Hand LH Driver Side Door Check Stop Linkage
2005 2006 2007 2008 2009 Chevrolet Equinox
Genuine GM Part Number:15861661
Aug 14, 2010 | 2005 Chevrolet Equinox
Left door pops open when right door is closed Also
its a very airtight unit so sometimes the doors popping open when another is closed sort of briskly is normal, or the door has gotten tweaked/bent so its magnetic gasket is not making really good, firm contact with the frame to hold it shut..
the water dripping is (if memory serves me correct) the condensate drain for the unit was prone to sometimes getting clogged, or the pan leaking. you may be able to get a ladder and climb up to the cooling box and see where the water is leaking from and remedy fairly easily.
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | True TM-52 Commercial Refrigerator
I need to level the refrigerator
You can level the left and right side but the front top should be leaning slightly back toward the wall behind so the doors will close properly. Remember to never level the refrigerator completely level as this will cause the doors to pop open when you close one the other will pop open. If you need more detailed information let me know. Sea Breeze
Jun 24, 2009 | Refrigerators
How to close the large back panel door? The door will not close and latch into place.
Disconnect the power and ethernet cable, open the lower paper tray slightly, turn your printer around where you have easy access to the back of the printer. Close the main door until it has full resistance. ( The lower right hand corner of the door will be bowed out. ) With the heel the the palm of your hand, "pop" the lower right hand corner of the door, swiftly. Turn printer around, push tray in, reconnect cables, and turn on printer with power switch.
Jun 16, 2009 | Dell 3100cn Laser Printer
Right door will not stay closed
Put vaseline on door seals
May 26, 2009 | Maytag MSD2758GEW
French door refrig..right door pops open when left door is closed
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Right Hand door swings open too fast
On the bottom of the door there is a part called a door closure kit.It operates like a cam. There are high and low points on the part that aid in the opening and closing of the doors. Do-it yourselfer project.
Nov 10, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
