Question about RCA D56W20 56" Rear Projection Television
I have a 56 inch rca that blinks three timeswith a humming noise but wont turn on
  • 3,037 Answers
The 3 blinks (an error code) and the hum (most likely from the flyback) indicate that the flyback transformer is bad and needs to be replaced as the simple way of putting it (fairly common problem with projection tvs). If you plan on doing it yourself, then you should have some electrical expertise since working in a projection tv like this can be very dangerous otherwise I would go through the local shop. Let me know how this turns out for you.
Benjamin
Posted on Jul 18, 2009
56 inch samsung dlp wont turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 05, 2014 | Samsung DLP HL-P5663W 56" TV
Wont turn on loud ossilating humming lamp light blinks for a few minuits then all three lights blink
YOU may have a bad color wheel, it is very common. The wheel will before it fails produce a loud high pitched sound and or a grinding noise.
The wheel turns at 14,000 RPM and they frequently fail.
if the wheel is shattered the set should not allow the lamp to come on (you should be able to look behind the set and see if lamp comes on for even a few seconds)
See attached photo of color wheel used in some of these sets; if it is the problem the internet not only offers them for sale but there are video and written instructions for customer replacement of this part.
If this has told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Samsung DLP HL-P5663W 56" TV
RCA HD56WW66 green light blinks three times then nothing
install the RCA repair kit called the CP50, CP120 and CP114 repair kit from www.tvrepairworld.com the kit also contains the instructions on Cd
Apr 14, 2010 | RCA HD56W66 56" HDTV
Why does my d56w20 link 3 times with a humming noise
3 Blinks is just saying that there is a problem , and the fault is often concerning teh deflection circuit. The pcb is located behind the back panel, on the bottom left hand side, the firt thing the technician will do is looking for leaky or bulged capacitors in there, checking horizontal and vertical output and testing the the resistors on the deflection circuit.
Jul 18, 2009 | RCA D56W20 56" Rear Projection Television
Vivitek 56 inch dlp projection is humming. why and how to fix
In my experience, the humming means your color wheel is going. The bearings inside the wheel are probably giving out.
My Vivitek started humming a couple of months ago and first I replaced the lamp.
Still hummed.
I read in other forums that humming is linked to color wheels and that seemed like where the noise was coming from.
I purchased a new wheel online and replaced it myself...
..no more humming, the picture is great and now I can listen to the movie again...not the tv!
Mar 17, 2009 | Vivitek V37655 56" DLP TV
Rca 56" has three blinks
Have you checked the hori output transistor bet it is shorted .
Feb 19, 2009 | RCA D56W20 56" Rear Projection Television
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
RCA D56W20 56" Rear Projection Television Logo
121 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
