Question about InFocus IN72 Multimedia Projector
After changing the lamp on my in72 there are vertical lines of white dots through the entire picture. someone said the color wheel is scratched?
  • jimbutler689 Jul 18, 2009
    were can i get a new color wheel and how hard is it to replace
  • 3,230 Answers
Yes it seems color wheel problem....
check for scratched.......
Good Luck!!
Thanks
Posted on Jul 18, 2009
  • Mukesh Kumar Jul 18, 2009
    You can get the color wheel from the InFocus dealer...
    Follow the below link to know how to replace the color wheel -
    http://home.comcast.net/~jexkids/Ebay/co...
    Note. the link provided is of another model of InFocus.... but it's the same procedure with your's
    Thanks
There is a humming in back of tv.the sound always good but picture doesnt come thru and i get a green screen someetimes blurry with distortion.color wheel or dmd chip or lamp starting to go out
as my experience, the most possible reason should be the color wheel or its photo sensor board.
firstly try to clean its photo sensor board, or have to replace a new wheel.
i just have this wheel, when you need to replace it, contact me freely
May 02, 2016 | Televison & Video
Square "zones" of bad vertical lines in picture lines appear white Replaced color wheel, remained same
it is not correlated with color wheel
you can do following these:
1,the interface between the mother board and DMD drive board
2,to clean the the interface with some alcohol
3,securely plugged
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Mar 09, 2014 | Samsung SELECT HLR5656WX/XAA Rear...
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
The projector turns on to a blue screen for about 5 seconds and then switches to the red light bulb dot. i heard there could be a problem with the color wheel from someone?
When the color wheel starts to go out, what happens is the picture will usually be very faint and pulsate with no color (just black and white). This will last for about 10 to 20 secs then the projector will shut off. If you have a clear picture then it could be your lamp. Need more info. Does the projector shut off after the red light appears? Also you can pull the lamp out and clean the contacts with electrical contact cleaner which can be bought online or at your local radio shack. Pick up some denatured alcohol while you are there. While your lamp is out, use compressed air to blow out dust and debris from the fans and color wheel. You can clean one side of the color wheel very easily while the lamp is out. Use a q-tip with the denatured alcohol. Wipe from the middle towards the outer part gently. If you do it at a slight angle you can turn the wheel while you clean it. To clean the other side requires removal of the outer casing. Make sure your lens is clean as well. Use the compressed air to remove dust/debris from it. If you notice smudges on the lens, you can clean it with the denatured alcohol. Do not use any other type of cleaner on it and use a very soft cloth, preferably one made for cleaning plastic eye glasses. Be very gentle as the lens can easily be scratched. A build up on the lens can cause the error you described as well. If you are able to get into the menu, check and make sure your lamp hours are not maxed out. If they are reset the counter.
Oct 14, 2010 | Optoma HD65 DLP Projector
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
We have a model HL R4667W--Our picture just went
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
May 03, 2010 | Samsung HL-P4667W 46" Rear Projection HDTV
My five year old Toshiba 57H84 rear projection TV has a pink tinted screen when you first turn it on, then after it warms up, the colors are all fine but then the picture has evenly spaced blue tinted...
Apr 30, 2010 | Toshiba 57H84 57" Rear Projection...
Apr 14, 2010 | Toshiba 42H81 42" Rear Projection...
Samsung HL-P5063W audio is fine, no picture. Initially made a loud buzzing sound, so we replaced the color wheel. No more buzzing sound, audio is fine, but screen is various shades of white. Left TV on for...
Apr 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
InFocus IN72 Multimedia Projector Logo
104 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
