Question about Vacuums
Where do i find the drive belt for the drive belt for the beater bar on the morphy richards 73310
  • 97 Answers
Try to go to there website
Posted on Jul 20, 2009
Tip
Burning rubber smell from your vacuum?
Drive belt is slipping.
Remover cover from the bottom of the power head or base if upright style. Usually just 2 to 4 screws.
You will see a belt (thick rubber band) connecting the beater bar (roller with brushes) to the motor. Remove the beater bar and belt. You do not need to remove the motor. The beater bar will be held by clamps and screws. Remove the screws and clamps and lift the beater bar directly up.
Take the belt to your local vacuum dealer (note make and model) and get a replacement.
Installation is the reverse of removal.
Note: you will find a lot of hair and junk twisted around the beater bar. Take the time now to cut it all off.
Hope this helped. Please rate this if it helped you.
on Mar 07, 2010 | Vacuums
Belt replacement
It's a fairly simple job. The belt just loops over the end of the beater bar and motor shaft. Need to take the cover off the beater bar housing to get to it. Most difficult part is stretching the belt while putting the beater bar back in the housing.
Charlie
Aug 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum cleaner not picking up
Remove the beater bar and check in the suction cavity behind it. That's where they usually plug.
--W/D--
Jul 18, 2009 | Vacuums
Howdo I replace dyson belt??
Replacing the belt on the DC-17 is not complicated at all. Once I understood how, the process took about 5 minutes. My best suggestion is to call Dyson and they will quickly and cheerfully walk you through it without making you feel stupid. Here is what they told me: 1. Remove the bottom plate that covers the beater bar, using a flat head screwdriver; pull the beater bar out so that it is only attached by the belt. 2. Use the flat head screwdriver to wedge the belt off the beater bar. It takes a little bit of wiggling, but it is not difficult. 3. Once the belt is free of the beater bar, use the screwdriver to unhook it from the gear that is attached to the motor inside. 4. With the new belt, repeat the steps in reverse, hooking the new belt onto the motor gear, over the beater bar, etc.
Apr 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
My Oreck beater bar is not turning. The bar is free of hair or strings, the motor is working, just the bar will not move
If the motor is working then check the drive belt. There's a door on the right hand side of the Oreck that comes off with a cross head screw. Check the drive belt isn't broken. If its intact then its a possibility that the beater bar has seized up - beater bars from Oreck are available although you should check EBay to see if you can get a cheaper part. Sounds like a drive belt problem though.
Mar 05, 2009 | Oreck XL2600 Vacuum
I smelled something like rubber abd now it won't pick up anything.
In all probabilty, your beater bar brush was jammed and the belt that drives it was stuck while the motor that drives it was spinning. This problem will manifest otself as a burnt drive belt. If you can open up the base part ( where the beater bar is) and examine that area for the drive belt..chances are you wil find the problem.. while there.. make sure your beater bar is free to rotate ( power should be removed or disabled while checking all this) Hope this helps...
Sep 21, 2008 | Bissell Vacuums
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Vacuums Logo
70 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
