Question about Toshiba MK6026GAX 60 GB Hard Drive
Protable drive blinks as trying to read a file but wont connect
Have toshiba 500 gig portable USB dive. I just unpluged it yesterday without remove hardware option. Now thw computer wont reconize drive when pluged in, drive light blinks as if it is trying to read a file or transfer information.
  • nicholas337 Jul 18, 2009
    Amruthls you asked:
    Did you try it in another computer? Is your OS Vista
    Reply: The OS is XP Home. and yes i tried it on another computer also XP. Also made mistak model # is HDDR500E03X
  • Amruth Louis May 11, 2010
    Did you try it in another computer? Is your OS Vista?
  • 32 Answers
Nicholas, you might want to try plugging it into your computer (with light blinking) and restart your PC with it still plugged in, just ot see if your PC recognizes the drive on start up. Otherwise, I would try some -hard drive utility- software to see if it can be 'unlocked' or recovered. Hope this helps.
Posted on Jul 18, 2009
  • 416 Answers
Have you tried the device on another computer?
Cannot rename hard drive
autorun.inf is a hidden system file. Make sure you can VIEW hidden files. Then look again at your portable drive's root folder.
(View TAB in your file explorer - Hidden Files checkbox)
Jan 28, 2014 | Toshiba Canvio 500 GB USB 3.0 Portable...
Can't rename my canvio 3tb hard drive
Check to see if there is a file in the root directory called "autorun.inf". (Make sure you can view hidden files.) If there is, either delete it, or move it to a backup folder. Now you should be able to rename your portable hard drive.
If you don't see the new name take effect right away, Safely remove the drive, unplug it and plug it back in. The changes should show up immediately.
Sep 14, 2013 | Toshiba Canvio 500 GB USB 3.0 Portable...
I cant rename my toshiba canvio 3 1tb
Mar 02, 2013 | Toshiba Canvio 500 GB USB 3.0 Portable...
My toshiba 65hm 167 wont come on
If you are refering to the 3 yellow blinks repeated over and over the
boot data is corrupted. Download the firmware update(link below)from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses, don't use bigger than a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good.
Jul 01, 2012 | Toshiba 65HM167 65" Projection Television
Rename toshiba external hard drive
Check to see if there is a file in the root directory called "autorun.inf". If there is, either delete it, or move it to a backup folder. Now you should be able to rename your portable hard drive.
Mar 19, 2012 | Toshiba Canvio 500 GB USB 3.0 Portable...
I have toshiba 250 gb HDDR250E03X i am unable to write a data of 4 gb or more(single file of 4 gb or more)..?
Hi this is a file system issue. It is probably formatted in fat32, which does not support files above 4 gigs.
To solve this problem you'll need to reformat it (my computer => right click on the drive => format), using ntfs file system (under file system select ntfs).
Note:
THIS WILL ERASE EVERYTHING FROM YOUR DRIVE!
So back up everything before proceeding.
After it is done you will be able to copy files of any size onto it.
Alternative solution: download winrar and split your files into chunks smaller than 4 gigs.
Jun 30, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
Copied files to a folder on portable harddrive
1. Try creating another folder and coping the content from the original to the new folder on the USB drive.
You may have stopped the coping process inadvertently during the copy process.
Apr 07, 2010 | Toshiba 120GB USB 2.0 Portable External...
Hard drive not showing in bios
It appears that your #2 hard disk has died. To test if it is faulty, remove the #2 drive and connect it to an USB hard drive adapter and plug it into the USB port of a working computer. If the computer see it as an external USB drive and you can see the folders and open the files, then it is OK and the fault is possible the disk controller.
If the hard drive is not recognised then it is faulty and needs to be replaced.
Jun 27, 2009 | Toshiba Qosmio G15-AV501 Notebook
Toshiba MK6026GAX 60 GB Hard Drive Logo
237 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
