Question about Poulan Garden
My weed eater blower starts and i can run the engine at full
Speed if i remove my finger from the trottle and try to bring the engine to full rpm again it dies if i want to start it again i've got to use the choke and keep playing with the choke lever on/off otherwise the engine dies i've removed and opened the carb (cleaned it) many times after i re-assemble it to the motor it starts i run one time after that it's the same thing. the next time i will use my hammer to fix it, please help.
    Problem Solver:
  • 12 Answers
See if there's a plastic adjustment/tiny little unit with standard slot,try half turn.
Posted on Jul 20, 2009
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Carburetor adjustment procedure
    low and hi speed mixture screws
    one adjusts for proper idle
    one adjusts for proper high rpm operation
    turn them in or out to get the best throttle response and proper wide open throttle rpm's
    Aug 26, 2014 | Weed Eater Fl1500 Le Leaf Blowers
    My Weed Eater FL1500LE gas leaf blower will not run beyond the full choke setting. If I move the lever to half choke the engine will stop. Or if I move the throttle from full throttle to a lower speed...
    This is a tell tale sign of a lean fuel mixture. By choking the unit you are manually creating a richer fuel mixture. I would purchase a compression tester from a local parts store and check compression. If that's ok, I'm willing to bet the problem is still carb related. Two stroke carbs are tricky to clean because of high/low ports that are one way and sometimes impossible to clean. Did you remove high and low needles when cleaning carb? Another trick is to mix seafoam with your gas, then mix two cycle oil to proper ratio. Use 2 ounces seafoam to one gallon of gas, then mix two cycle oil to proper mix. Hope this helps! Good luck and happy wrenching!
    Sep 22, 2013 | Weed Eater Fl1500 Le Leaf Blowers
    Weed eater fb25 won't start
    This blower is fuel sensitive! Gas and oil mixture has to be correct. Too much oil will cause carbon buildup in the cylinder. In my case my blower would not start after several uses this season. I checked EVERYTHING....spark, fuel delivery, air filter.....then checked the flywheel which has no separate key....the key is cast into the flywheel. Read somewhere about the carbon buildup so took the cylinder off and viola! The piston ring was firmly stuck in the piston groove plus the cylinder was carbon scored. I tried to gently pry the piston ring free but it was so firmly stuck, it broke. Not worth fixing. Take the muffler off and you will be able to see the piston ring....use a small pick or something to see if the ring is free. If not, proceed to tear down or throw out. I was able to see scoring on the piston and determine my ring was stuck this way. Remember the elements needed for successful ignition...fuel/air...spark....compression. Stuck ring = low compression. The last time you ran the blower the ring became stuck...the engine continued to run because of the engine rpm's but when you try to start at low RPM's, no luck.
    Jan 18, 2012 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    Blower only runs with full choke. When I switch to half choke, it dies and won't start.
    it may simply need the high speed jet opening up a bit (2 screws near eachother on the carb and the high speed is furthest from the engine)
    failing that it needs a carb kit.... this is a serviceable item changed regularly.
    Mar 14, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    My weed eater starts but won't stay running. what
    Try a new spark plug.Thanks for asking and I hope it helps
    Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    Blower does not seem to be getting fuel, last few usages required chock on to run, will start if gas poured in intake, but will not continue to run. cleaned out carb and fuel lines. What is the likley...
    carb needs to be removed and thoroughly cleaned out,and rebuilt from varnish in the oil/gas mix,also remove the muffler and de-carbonize this also as it will create back-pressure and slow the rpm's and power output after time
    Mar 23, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    My Ryobi weed eater loses power at working speed after 5 minutes.
    you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
    Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    Poulan pro 25cc will start but not continue to run.
    Is it difficult to pull? If so it could be the exhaust flame arrester has fouled with carbon. Over time it will become completely clogged and will not allow the engine to come up to speed or even start. Remove the exhaust and you will find the screen on the inlet side of the exhaust.
    Apr 26, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    Garden Logo
    505 people viewed this question
    Top Poulan Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
