Kymco Maxi XL Mobility Scooter Logo
Megan palmer Posted on Aug 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a kymco agility mobility scooter and there is a very noticable clicking noise when its moving. Help?
Jeff Bird
Level 3:
  • Kymco Master 1,348 Answers
  • Posted on Aug 27, 2016
Jeff Bird
Kymco Master
Level 3:
Answers
1348
Questions
0
Helped
363331
Points
4615
Hi tighten the axle nuts ...if this does not help loosen axle nuts jack it up tighten nuts & when on the ground tighten them again, cheers
5 Related Answers
Anonymous
  • 2050 Answers
  • Posted on Dec 09, 2009
SOURCE: i was on my kymco scooter the other day and it
Sounds like, and this is general, you may have engine damage.
Get it checked out, or do a compression test if you are able.
tombones
  • 3567 Answers
  • Posted on Apr 10, 2011
SOURCE: Hello I have a kymco
The nut should turn counter clockwise to loosen.
Anonymous
  • 33 Answers
  • Posted on Jul 02, 2011
SOURCE: 2007 kymco agility 125cc scooter
could be one of a few things. Most likely fuel related. 1) carb blocked main jet (whip it out n clean it) 2) air filter clogged up or split (remove spark plug and if it is black there is too much fuel and either the airfilter is blocked up or the choke is stuck on, if it is very white there is too much air getting infrom either a split air filter or leaking inlet pipe) 3) change spark plug.
Anonymous
  • 3 Answers
  • Posted on Jul 21, 2011
SOURCE: Derestrict 2007 kymco agility 50?
Ckeck spark plug,batterie,put super fuel with a hight level of octane its gonna clean ir engine .
rilaxson
rilaxson
  • 456 Answers
  • Posted on Mar 16, 2013
SOURCE: My kymco agility 50cc has no compression
Is the spark plug in,did this happen all of a sudden
Tyre pressure on Kymco Agility 125 Scooter 16+ ?
agility city 125 Workshop-manual : Page 3 - bike-parts-kymco.uk
bike-parts-kymco.uk https://www.bike-parts-kymco.uk > catalog > page3
Order your original Kymco ATV, Scooter & Motorcycle spares with our part diagrams ?? Search by model or part number ?? Manufacturer warranty - Secure ...
Tires sizes for KYMCO Agility 125 2017
MotoTireFinder.com https://www.mototirefinder.com > ... > Agility 125
What are the tires pressure for KYMCO Agility 125 2017? · 25 PSI (~1.72 BAR) · 32 PSI (~2.21 BAR).
Front Tire Pressure: 25 PSI
Front Tire Dimensions: 120/70-12
Rear Tire Pressure: 32 PSI
Rear Tire Dimensions: 130/70-12
1helpful
What year was the mobility scooter manufactured? Kymco Agility
The manual is dated October 2014. Use 2015 as your date. Or ask them direct based on the serial number.
KYMCO Agility User Manual
https://www.manualslib.com/manual/972938/Kymco-Agility.html#manual
Advertising specs
Kymco Mobility Scooters Agility
Kymco UK https://www.kymco.co.uk > AGILITY-eq35fa
QUALITY, STYLE & PERFORMANCE! The new Agility compact 8 mph scooter offers high performance with comfort, making everyday journeys a pleasure!
Maximum Speed (Kph / mph): 12.8 Kph / 8 mph
Wheel Type: Pneumatic
Calculated Range (Km / Miles): 40 Km / 25 Miles
Turning Radius (mm): 1560 mm
How do I fix an Kymco Agility 50 motor scooter that doesn't start?
Question edited for clarity, changed 'carbonator', (a thing that puts bubbles in soda) to a carburetor (a device that atomises gasoline).
The new battery is fine, in fact 6 amps is better. It has more staying power and will start the bike easier in cold weather. It is better for your lighting as well. The problem is likely to be that your battery is not fully charged when you got it. Put it on a 2 amp battery charger for 8 hours.
These two adverts have 4 amp and 7 amp as suitable.
Kymco Agility 50 Scooter and Moped Replacement Battery ...
https://batteryclerk.ca > ... > Scooter and Moped Batteries
Kymco Agility 50 Scooter and Moped Replacement Battery (2009-2016) · Voltage: 12V · Capacity: 7Ah · Cold Cranking Amps: 135 · Polarity: +/- · Terminal: B · Dimensions ...
1helpful
2answers
Why won't my Kymco start? Has power to everything and the relay swifch clicks, that's all it will do
KYMCO Agility 50 Scooter Online Service Manual ...
https://www.cyclepedia.com/...manuals/kymco...scooter...repair-manuals/...
The CYCLEPEDIA PRESS LLC KYMCO Agility 50 Scooter online service manualfeatures detailed, full-color photographs and wiring diagrams, complete ...
Top Kymco Health & Beauty Experts
john h
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you a Kymco Health and Beauty Expert? Answer questions, earn points and help others
