Question about Cell Phones
Me too. i have the exact same prblem..mine r the ok button and the * 0 # numbers
  • Cell Phones Master
  • 805 Answers
Key problem. go to tecnician
Posted on Jul 19, 2009
Tip
MOTOROLA TIPS
Motorola Secret Codes
IMEI number:
*#06#
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
Important!
Try these codes at your own risk! We don't accept any complaints.
Some of these codes may not work
on Sep 27, 2010 | Cell Phones
Purchased region free pet7402a/37 in US, I am in europe and it plays "wrong region", any suggestions?
I just unlock mine PD7012/37 today, I think you can use de same sequence:
1- Power on without dvd;
2- In SKIP button, right side of SETUP, press "RIGHT", "LEFT", "RIGHT", "LEFT", "RIGHT", "RIGHT", "LET";
3- Will appear a menu, go to REGION using "UP" navigate button, and press OK, select "TEST 0" using navigate button and press OK.
4- Press STOP;
5- Enjoy.
Apr 12, 2011 | Philips PET7402A/37 Player
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
How to get OK-CLR sequence to unlock keyguard??
I have a black one too, but I was able to set both the OK and CLR buttons to unlock it. If you go into the settings on the front keypad, go down to keyguard settings, then unlock options, you should be able to choose Two Step Unlock. That will enable you to hit OK then CLR to unlock.
Dec 30, 2008 | LG enV VX9900 Cellular Phone
I have an LG DR389 DVD recorder I want to unlock the regiond so I can play DVD's from the UK
This just worked on mine - I have this exact model.
- Press the "home" button
- Go into "Setup - Start"
- Scroll down to the "Lock" icon
- Press the number "0" seven times
a thing comes up on the screen saying it's successful or something.
I believe this works for other LG models as well.
Cheers :)
Aug 03, 2008 | Televison & Video
Texting
please contact your network ""wireless service""..it is undoubtly the network provider prblem and ur mobile is safe and sound..all the best
Happy to help
Have a nice day!
tc
May 30, 2008 | Nokia 6300 Cellular Phone
Unlock codes
here are set of code that you can apply and play with. You should have included the model of your cellphone but i'm hoping that this would help.
Enable EFR:
Function :
Change pin:
under "Opcode"
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Jan 04, 2008 | Lands Phones
Cell Phones Logo
52 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
