Question about Garmin NUVI 360 GPS Receiver
Our GPS keeps saying "Navigon software cannot be started." a yellow/organge light is shining to the right of the reset hole. we checked and the computer chip seems to be intact; it had fallen out the last time we had this problem. Nothing happens when we push the start button and put a paper clip into the reset hole. We're traveling and don't have the name (by the way - we are lost!!!). It says Canada 310 FC underneath.
  • 1 more comment
  • kentmillard Jul 18, 2009
    we may have given you the wrong number for our Navigon. On the bottom it has Canada 310. The first guy suggested we raise the GPS antenna; we have no GPS antenna. The next solution was to push the upper right corner of the screen and check YES. I clicked the upper right corner but nothing happened. The Navigon screen continues to read: NAVIGON SOFTWARE CANNOT BE STARTED. HOLD THE ON/OFF KEY PRESSED AND PRESS RESET SIMULTANEOUSLY. nOTHING HAPPENS WHEN WE DO THIS.
    HELP! KENT MILLARD
    HELP! KENT MILLARD
    We can't get the micro chip out of the device. We push it in with a pencil point or toothpick but it doesn't pop out like it should. What should we do? Kent Millard
  • 3,037 Answers
Remove the Micro SD Card
Turn the device off by depressing the power button on the upper left for 10 seconds.
Insert the Micro SD Card and turn on the device.
The software will start and the device will become functional again. This can take up to 40 seconds.
If the above doesn't work, try updating the software from their website. If that still doesn't help, then start looking for a broken and/or loose connection around the computer chip. Possibly a dirty connection. Let me know how this turns out.
Benjamin
Posted on Jul 18, 2009
  • Benjamin Patri
    Benjamin Patri Jul 18, 2009
    You can pull it right out without it popping. It won't wreck nothing, the popping out is a convenience for the user. Use a needle nose pliers if needed
    Genius:
  • 3,422 Answers
HI,
You will have to reset your GPS to fix this issue.First go for a soft reset.This will not erase any saved data.If the soft reset does not fix the issue then you will have to go for a master reset.This will erase all the data and restore your GPS to the factory defaults:
SOFT RESET:
1)Disconnect Nuvi from External Power
2)Flip up the GPS antenna and press The GPS button
3)Connect Nuvi to a power source,The nuvi should automatically turn back on and operate normally.
MASTER RESET:
Hold your finger to the upper right corner of the Nuvi screen while you turn on the nuvi.Keep you finger pressed until the pop up window appears.
Touch YES and all factory settings are restored.Your reset selections and audi bookmarks are also deleted.
Thank you.
My Navigon GPS says the software cannot be started. Please reset your devise. What do I do to reset it?
what brand name is it ? if it is Garmin then there should be a button on the back of it or bottom it is small just hold it for a few seconds then it should reset it all. hope it works
Feb 28, 2011 | Navigon GPS
I have a Navigon 2100Max 4.3" GPS. When it turns on freeze at the Navigon screen. I tried to reset it won't work. Their website is no help. Please help.
Please remove the battery for a minute or so. If the problem still persists then have the firmware reinstalled as it has got corrupted.
Dec 14, 2010 | GPS
Navigon software cannot be started. Please reset your device. Thats the message I get when I turn my navigon 2090S on. Can I get help
there is a reset hole somewhere on there that you could fit a paperclip in, click on that for 5 seconds and it will reset your device for you
Dec 29, 2009 | Navigon 2090S Car GPS Receiver
Navigon 2000s I cannot reset the Navigon 2000s
Well after many emails to Navigon I got the fix for my 2000s What you have to do is download the 1.2 version software for the 5100 install it on a 2GB micro SD Card. Put it in the slot and turn it on. You will have to regester as if you have a 5100 but it will work. The reason you have to use a 2GB card is the maps are to large to go on the internal memory.
Jun 09, 2009 | Navigon 2000S GPS Receiver
My navigon 2110 wont turn on
2 things that might help...use a paperclip and press the reset button (small hole on side, you'll feel a click) hold it for 5 seconds. THEN hold down the power on button for over 10 secs (keep holding while it shows version number) and it will perform a factory reset. You will likely lose any settings and addresses, but better that than no GPS unit.
May 10, 2009 | Navigon 2110 Series Satellie GPS Receiver
I HAVE A MESSAGE ON MY 2100 GPS,SAYS MN6 .EXE HAS PERFORMED AN IL
Sounds as if the system software that runs the GPS has been corrupted. Your device should have come with a CD that has software that can be reloaded or a utility that can be installed on the PC that connects to the navigon website to download and install the software for you.
Might want to start with that.
Hope this helps
TankMurdock
Apr 24, 2009 | Navigon 2100 Max Portable GPS System
Navigon 2100 problem
2 things that might help...use a paperclip and press the reset button (small hole on side, you'll feel a click) hold it for 5 seconds. THEN hold down the power on button for over 10 secs (keep holding while it shows version number) and it will perform a factory reset. You will possibly lose any settings and addresses, but better that than a locked GPS unit.
Oct 10, 2008 | Navigon 2110 Series Satellie GPS Receiver
Garmin NUVI 360 GPS Receiver Logo
77 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
