Question about Hayward SAND FILTER, PRO SERIES
Algacide? The pool store keeps saying that I should not put algacide in my pool with the shock. This is for the green pool. I've shocked 3x and still ever so green. CONFUSED
    Scholar:
  • 86 Answers
I think he meant not to MIX them. Don't put them in together.
If your water is still green, it definitely needs algaecide. Be sure you get the bottle that says it will KILL algae, not the preventative. (only difference is the concentration of the product.....preventative is diluted more).
After adding the algaecide you will have cloudy water looking like very very tiny white things floating in your water. Buy a bottle of clarifier to help solve this issue. It will allow the 'dead algae' white stuff to clump together and be vacuumed up. Water will be clean and clear in no time!
Hope this helps. Good luck!
Posted on Jul 30, 2009
Is this pump large enough for a 18X48 easy set pool? I have been unable to get this pool clear dispite my best efforts with chemicals and taking samples to be tested. I really feel it's not a...
THE PUMP IS LARGE ENOUGH. i HAVE THE SAME . ALL U NEED IS TO BRASH YOUR POOL ONCE A WEEK WITH THE PUMP RUNNING SO THE PUMP SUCKS ALL THE ALGAE AND THE RUBBISH FROM SCRUBBING.
Aug 06, 2011 | Intex Krystal Clear Model 635 Pool Filter...
My a/g pool is going green. I have shocked it three times this week with minimal improvement. I use the powder form super shock. Any tips would be great. My first pool. Its been 100 degree with 98%...
There's a product called banish (algae killer) that worked wonders on my pool one summer. It also may take much more chlorine than you think. Once you get rid of the green - keep your chlorine up at about 4 or 5 when it is this hot to prevent a repeat.
Jul 22, 2011 | Pool & Spa
I have an intex salt water system for my 16ft round pool. My FC level is reading 0. Should I proceed to boost the system. PH is high also. Thanks.
run your generator for the full 12 hours. You need some serious sanitizer or you will be going green soon.
Also add some stabilizer so that the chlorine level does not drop so easily
As for the ph hit it with some ph down
It wouldnt hurt to get a bottle of non foaming algacide also
Jun 24, 2010 | Intex Automatic Salt Water System for ...
I have a 16x32 dished out pool; average depth 5.5ft
First of all to answer your question. Yes the intex generator will work with a 16x36
Where do you get an average of 5.5ft when you say the pool is 36" deep
Well now the bad news. A salt water system will not solve your algae problems
Algae comes from wrong pool maintainence
You must now with a green pool shock your pool with 1 gallon of chlorine and now with a pool brush brush the sides and bottom now wait 4 hours for things to settle.
now vaccum clean cartridge if applicable or back flush your sand filter
wait 24 hours and brush again.
Continue to do this until it starts to clear watch your chlorine level and if it starts to get low shock again until the green goes away.
You will also need to buy an algacide, non foaming and follow the directions usually 14-24 ounces per 10,000 gallons of water
also put a stabilizer in your pool to help maintain your chlorine level. It will still drop but not as fast
one of the main contributing factors to a green pool or lack of sanitizer ( chlorine ) is # of bathers,sun,heat,sun
tan oils, and even the most common problem Lack of use.
The water needs to be constantly moving to help prevent algae. If you do not use it for a few days or so then brush it even if you do not see algae Guarantee if you go in the pool a few days later after not using it for a bit you would feel the slipperyness HMMMMMM is that a word anyway you would feel it
Another thing to consider is to filter filter filter
unless you have a 4000 gl ph pump you can not get enough filtering with an intex pump.
a pool should be turned over at least 3 times a day this means if you have lets say a 5000gallon pool and a 2000 gl ph filter you will need to filter at least 7.5 hours and that is at the low end
An intex pump pulls about as much energy as a 40 watt light bulb I have aintex 2500gl ph pump with a 7000gl pool I run my filter 24/7
Bottom line is you do not need a salt system that is just one more so to speak chemical to maintain at a certain level
Stick with getting your chemicals right and your problems will go away if you have any more questions or something specific just e-mail me
Jun 20, 2010 | Intex Automatic Salt Water System for ...
My pool water turned green after I put an alkalinity and ph stabilizer in it what can i do to get it clean again?
Pure bleach, gets mine clear when it turns green. If its just clear water with a green tent then i would use bleach. I only use bleach to maintain my pool. I have a 20 round 88,00 gallon pool and i use 1 and half gallons of bleach every week to keep my pool clean and i use a bag of shock it every month or so, all the shock is used for is to drop everything to the bottom so i can vacuum it. If u have a smaller pool then i would use about 3/4 a gallon a week on a 15 round 5,000 gallon pool and about a half a gallon for a smaller pool. But it will for sure get ur water clear and if u dont want to use bleach then shock it will do it and to maintain use the shock it atleast once a week. When u use the bleach make sure u pour in over the where the water returns in your pool slowly to help it not hit the bottom. When u pour it over the clean water that is returning to your pool then it will help spread it throughout your pool and dilute it so it wont spot your liner up with lil bleach spots. So just pour it slowly over the return water comin out of the side of your pool. Also if its an algea problem then bleach will def work to prevent and kill the algea and u can u an algeacide to get rid of it if u dont want to use the bleach. The bleach is the cheapest way and fast way i have found to keep a pool clean. My pool is cyrstal clear, u can see any specs that is floating in it I hope this helps, please let me know what u think and rate solution. thanks and good luck
God bless
Jun 15, 2010 | Intex Easy Set Pool 15x36
Salt water intex pool
Salt chlorine generators cause your pH to raise over time. You will need to add acid as needed to keep it within the ideal range. When adding acid, shoot for the low end (about 7.2) so you have room for the pH to creep up again before needing more acid.
As for green water, what is your chlorine reading, if any? Probably need to shock it not only again but an even bigger dose than the first. Shock treatments are not cumulative. If the first doesn't do the job, adding just a little more will not either.
Oct 08, 2009 | Intex Automatic Salt Water System for ...
Shocking
test water to see if you have a free chlorine reading check ph we use 8 gallons of liquid shock with a water conditioner make sure you have vaccumed first to remove algea dont vac through pump put hose over top of pool start water flow with a wet vac at end of vac hose just turn on vac to start water flowing
Jun 16, 2009 | Intex Automatic Salt Water System for ...
Green water
Chlorine generators raise your pH over time. You will always have to monitor and, on occassion, adjust your pH down using acid. Your water being out of balance likely lead to the green water condition.
Check your alkalinity first and adjust it if needed. Once it is stable, adjust pH using acid, then get your pool shocked to kill off the algae. You made need an algacide too but save that for last and only if required.
Hayward SAND FILTER, PRO SERIES Logo
253 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
