Question about Emerson Coffee Makers & Espresso Machines
Just bought the machine and no water is coming through the espresso maker...coffee maker works fine
  • 2,039 Answers
Try to open the steam valve to ventillate the machine
Posted on Jul 31, 2009
2 Suggested Answers
SOURCE: Have a Salton EX 15 coffee Espresso maker and my
The reason why the setting dial is clicking, because it's stuck on steam only and when you turn the dial to make the coffee it's grinding instead of turning smoothly. you need to remove full top cover. And to do so, you need to remove the two screws hidden under plastic caps next to opening where you add water for espresso or steam. Once the screws are out you can lift the top of slowly unlocking the corners.Tthe dialer knob stay on the top cover. Using a basic plier or locking plier turn the nozzle stem to unlock it from steam position...When you put it back together make sure it's back on steam not so tight and put cover and dialer setting at steam. put back the two screws and covers...Enjoy... from : jenlwe.thecustomeradvantage.com
Posted on Nov 27, 2011
Cimbali M2 wont deliver coffee
Coffee may be to fine. To Check, open pill door and press any blinking button. If water comes out then for sure the coffee is to fine.
Nov 30, 2011 | Espresso RMI La Cimbali Espresso Machine
My delonghi caffee nero machine-the coffee maker wont work,the hot plate doesnt warm either(although the lights come on. the espresso maker part works fine. Someone mentioned there is a fuse which blows...
If expresso maker part works, the fuse is ok. I think that the resistence of the hot plate is interrupted. You must use the guarantee's facilities. I think it is two years available.
Mar 07, 2011 | DeLonghi Caffe Nero BCO264 Espresso &...
I have a Krups coffee/espresso maker, with a milk steamer. It makes great coffee and espresso; however, the steamer is not working. It is not clogged; I cleaned the handle with a fine needle, and water...
There must be a blockage in that steam pipe, I think you need to dismantle the machine and remove all of the steamer parts off the boiler and look for the cause of the problem. Oftentimes it will be old hard milk that has been drawn up the pipe and gone hard from the heat. Once cleaned out prevention by blowing a large amount of extra steam through it after each use is the solution.
Apr 22, 2017 | Krups Gusto 880-42 Espresso Machine
No water is pumping thru the water spout or the coffee spout, the machine is reading fine grounds and press okay for water. i've adjusted grinder dial and pressed water button but nothing happened
I got this machine and there was grinding noise but no water coming from the spout or coffee from the dispenser.
Took the back cover off. The big lump in the middle is the water pump. One of the wire connections was hanging off mine. Pushed the connector back on and everything worked fine.
Great coffee, rubbish construction!
Sep 18, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
There is no water coming out of the machine at all. No error light come on but when you go to make a coffee with beans or pre ground it goes through the process but just dry coffee comes out. Also no water...
For the steam check the end of the nozzle to make sure it is not blocked.
For the coffee run a coffee using the pre ground method but without coffee grounds, if water comes out then grinder is too fine, if no water remove brew unit and clean top shower screen, you might have to clean tube leaving from shower to discharge.
Aug 29, 2010 | Gaggia Syncrony Compact Coffee...
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
Need gasket for Alessi 6 cup stove top espresso coffee maker
I have a Elevation Espresso Coffee Maker it worked fine until today when it stopped heating the water. Any help would be great.
Regards
frank
Jan 21, 2009 | Alessi "Coban" Espresso Machine
Put water in put disk in heats then goes to auto .but no coffee comes out
popped grey button off little red push button in behind was off to one side .unplugged coffee maker and moved red button back in place very easily with small flat screw driver.works fine now.
Jan 04, 2009 | Braun Tassimo Espresso Machine/Coffee...
Cuisinart EM-200 espresso machine won't make coffee
you might check the water hose and make sure that it didn't come disconected. sometime they wear out over time and strech becoming loos. and when that happens the maker can not **** the water through the tube into the expressor mix causeing it to make u sucking noise.
Aug 01, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
191 people viewed this question
Top Emerson Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Kolbrun...
Are you an Emerson Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
