Has been standing for a while but batteries were removed and stored indoors with regular charging. Running fine- just the incessant beeping!!
SOURCE: Scooter just beeps when key turned
Hi. That fault is the speed lever. It can also be the small dial that alters your top speed. It pays to replace both of these at the same time. Some of these machines also develope the same fault from a faulty controller. Good luck. Neil.
SOURCE: batteries do not charge but charger is working.
mcdevito75 here, You may need new batteries, if they are 2 years old or more.
SOURCE: Rascal liteway 3 will not
Red light flashing 7 times is likely caused by problem with the speed control dial. Most likely something is wrong with the contacts. This type of problem needs attention by the service centre nominated for Rascal scooters in your area.
Check this site for details.
Hope you are able to get it fixed soon.
SOURCE: rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Left overnight and now stopped beeping!
