Question about HP Pavilion dv6000t Notebook
HP dv6000 Lights up but that's it.
Hi I am having an issue with a laptop and i just can't seem to figure out the problem.
When i press the power button, the lights all light up, the cd rom drive spins for a second and that's it. No fan, No Post, Blank Screen. After a few seconds, it shuts off and then turns back on and the exact same thing happens. it does this over and over again.
I have replaced the motherboard, and get the exact same result...
is it the cpu? Any ideas?
  • ps2176 Jul 18, 2009
    I did as you said and again had the exact same result. So assuming that the new motherboard was not faulty, the only other thing it could be would be the CPU?
    The thing the bugs me is that the fan doesn't even spin. Wouldn't the fan spin even if the CPU was bad?
    It was a bad motherboard after all. The new motherboard was good. It turns out i need a new heatsink\fan assembly as well.
    Thanks for the help!!
  • HP Master
  • 19,396 Answers
Re : When i press the power button, the lights all light up, the cd rom drive spins for a second and that's it. No fan, No Post, Blank Screen. After a few seconds, it shuts off and then turns back on.
That is generic hardware fault, any faulty device can cause the problem.
The motherboard must be started with a minimal set of devices to troubleshoot.
Start motherboard with only CPU, power adapter connected (faulty battery can cause the problem), heathsink, display and one memory stick. Keep unplugged HD, optical units, keyboard, minipci cards etc.
If problem persists, eventually test the motherboard using a post card(PCI & ISA PC Diagnostic POST CARD MOTHERBOARD TEST CARD) to ensure that new motherboard is not faulty, and then if cpu has not been replaced with the motherboard, replace CPU.
Posted on Jul 18, 2009
Hi ive got a HP Pavilion dv6000 laptop with a black screen ,i have tried a external monitor and i have checked the ram but still black screen ,the lights are on and the fan is running..please help
Just try to power cycle the unit by removing all power sources (battery, ac adapter) and pressing the power button for at least 15 seconds. If this will not work and you did not get an image from the external monitor, then you need your motherboard replaced.
Good luck.
May 19, 2011 | Computers & Internet
I have an HP dv6000 laptop computer, and, starting last week, the laptop acts like it's turning on (all the lights illuminate, fan starts for a second) but nothing on the screen, and then the laptop turns...
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Dec 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Laptop keeps cutting off seems to get hot fast
Hi:
The DV6000 series of notebooks have a problem with motherboard issues, to include WiFi Failure, video problems, and other issues. You can do your own research on this, but it is pretty widespread, to the dv2000, dv6000, and dv9000. Many HP owners were offered enhanced warranties, and at the minimum, received a discount on repair.
See what you can do, as it won't get any better for you.
Nov 10, 2009 | HP Pavilion dv6000z Notebook
HP dv6000 laptop will not power up
the motherboard has a defective power mosfet on the bottom of the MB beside on the power connector.
Jul 27, 2009 | HP Pavilion dv6119us Notebook
Pavilion dv6000 when power button is pressed,
Have you tried to boot the laptop with the power cable connected? Is the charging indicator on when you connect it to the adapter? If the charging indicator does not light up, check if your adapter output and try booting it with the power cable connected.
Jun 19, 2009 | HP Pavilion dv6000t Notebook
Power Issue turn on and is turns off after 2 sec
Could be a glitched battery. Turn it on without battery installed. Also, to eleviate the memory - take it out. The unit will still turn on. I have to go along with HP support, that's it's probably the mother board. Now all is not gloomy. Hp has extended their warranty on many models, Dv2000-Dv6000 to name a few. Ask for a supervisor.
Mar 21, 2009 | HP Pavilion dv1000 Notebook
Hp Pavilion dv6000 Won't start
If you have'nt done any upgrades like windows or memory
I think you just need a new fan
possibly power supply
if you take it to a small pc shop they will test power and fan for you usually on the spot at little or no cost
please don't forget to rate me
Feb 04, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000t Notebook Logo
267 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
