Question about Pentair 150k Minimax Ch Ng Mv Heater
Pilot light is on but burners will not kick on. If I turn on the switch I get no response. Once in a while the burners kick on the shut off after about 2 min. Then they will do the same thing on and off for about 30 min. More often the unit just does not turn on.
  • 864 Answers
Make sure the pipes are full of water. Check the thermostat to see if it is calling for heat. Make sure the thermostat is set to a temperature higher than the current temp of the water. If all those things are Ok then the unit may have gone off on high limit the last time you used it or the gas valve coils may have to be replaced. If there is a reset button for high limit press it. If the unit fires up but does not stay on then the gas valve coils may need to be replaced.
Posted on Jul 18, 2009
Goodman gmt070-4a wont heat, like the pilot light is out or something
turn gas supply on....turn gas valve to pilot....press down and hold to allow gas to come through pilot tubing.....light the pilot right by the thermal couple, once lit hold valve down for about 60-90 secs...then release ur hand on the gas valve and turn the valve to on position............make sure the bloody tstat is turned off before doin anything other wise burners will fire up soon as you turn valve to on position
Dec 05, 2013 | Goodman GMS90703BXA Heater
Hayward h250 propane will not heat water
need to replace fusible link and high limits and possible other safety circuit parts
Aug 07, 2017 | Hayward Pool Products Pool & Spa
Pilot light on hot water heater is out
you need to shut off the the red nob and turn the nob off in front take the cover off remove the heat shield turn the nob on top to pilot use a piece of paper to light put in next to pilot and hold button down for 20 to 50 secs pilot should stay lit turn nob on front then burner should kick on then you should be all good
Mar 21, 2012 | Water Heaters
The burners will not light. The pilot does light. I had my staff try to hit anything that looked a reset, but I don't know if the high limit switch has a reset or if the switch itself is bad.
The high limit switch has nothing to do with the pilot light, but will shut down the main burners. It the pilot light will not stay lit, then it is most likely the thermocouple. If the pilot light will not light at all, then gas is not reaching the pilot. Most likely, the pilot light tube is clogged with grease. When you push on the button to light the pilot, you are overriding all safeties inside the unit and sending gas to the pilot. Also make sure that the unit itself is getting gas. New regulations require a shut off within the hose that feeds the appliance which will shut off due to a surge of gas through the hose. To reset it, disconnect/reconnect the hose at the intake end and when you turn the gas back on, turn it on slowly.
Jun 11, 2011 | Pitco Frialator 35CS Deep Fryer
Pilot light goes out
The Tstat has a capillary that looks like a thermocouple but it isn't, its a bulb with liquid that expands and contracts based on temperature. A pilot can go out due to a high limit switch being week or getting to hot and that can be shaped like a thermostat capillary or can be simply a disc with a button if even there is a high limit on your stove. There likely isnt. So see the next suggestion.
I suggest lighting the pilot, turning on the main burners while watching the pilot. If the pilot shrinks in size, then check your gas pressures before and after turning it on and seeing if there is a wide variation. I would suggest the pilot is dirty or the pressure regulator is faulty.
Dec 19, 2009 | Grilling
Pilot light goes out when burners kick on burnham
Get a toothbrush and clean the **** off the pilot, could be partially blocked. Change the safety thermocouple. Check the plenum for cracks. A cracked heat exchanger can cause this.
Nov 07, 2009 | Goodman GMS90703BXA Heater
How to fix a gas fryer trouble to get it on.
It is either the gas valve or the piece that the pilot light heats up. After the pilot light gets so hot it heats the copper tube looking thing up and then that goes to a little box that kicks a little switch and lets the power through to the gas valve which then opens and ignites the burner. You can check for continuity on the 2 poles on the switch when it gets hot.
Jul 24, 2009 | Imperial IFS40 Deep Fryer
1986 Weathermaker SX 150 series, model S85X060-CC-1
There are 4 -steps for full run time to kick in a furnace.. step-1, inducer fan runs & prove thru the air tube which closes a switch and tell the circuit board to go to step-2, the igniter lights the pilot & prove its lit by heating the thermocouple, which tells the circuit board to go to step-3, opens the gas valve to dump gas in, which will light from the pilot light, and prove by a flame sensor metal stick on the last burner , which heats up and tell the circuit board Saying, ok , I've got flame.. step-4. when the box heats up, it closes a switch and turn on the main fan...! (Some gas-valves has a brain -or circuit board on top of them and are real sensetive to moisture..)
Sep 05, 2008 | Heating & Cooling
Pentair 150k Minimax Ch Ng Mv Heater Logo
492 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
