Question about Seagate Travan TapeStor 20 Travan Tape Drive
I have an old STT6201U tape drive from Seagate that I'm trying to install on Windows XP. Windows asks for a driver for a "Freecom USB-Atapi Controller" but I cant find one anywhere. Does anybody know where I might get this driver? Thank you, Richard - rlsuth@comcast.net
  • rlsuth Jul 18, 2009
    Thanks CajunKitty. Unfortunately, when I tried to open the DriverDetective installation, I just kept getting an error that it could not be opened, so I'm no nearer getting the driver I need.
  • 70 Answers
Hi Richard, I found a free download site for the driver that your Win XP is searching for. I am unsure of the format and installation process. But I do hope that this link will help you.
Good Luck!
http://www.driver-fix.com/driverdetective.php?t=Freecom%20Usb%20Atapi
Posted on Jul 18, 2009
I pulled the seagate 2.5"
When you use external adapters to plug drives into USB ports the drive needs to be set for mast not slave. The internal drive is one one channel and external drive is on a different channel so neither drive is a slave, both are masters with not slave drive present. Try removing the jumper you installed and try the drive, it should be seen because all windows XP or later do not need drivers for USB drives.
I hope this helps, if so please rate my solution.
BuddyMc
May 06, 2011 | Seagate Momentus 4200.2 100 GB Hard Drive
Hello, I'm trying to track down a USB driver for a Freecom FHD-1 external drive to run under Windows 98se (for the moment). Have checked freecom.com for drivers but am a bit dizzy after...
http://support.microsoft.com/kb/263218
Some info on 98se and USB issues. You should not need a usb driver if the usb port in your computer is already functioning properly. The only inconvenience you will have is your drive will work at the slower speed provided by the usb 1.1 standard.
The link below describes step by step installation of your drive in 98se
http://www.viking-direct.co.uk/speciallinks/gb/vkg/source/FHD1.pdf
Apr 05, 2011 | EliteGroup P4VMM2 Motherboard
NEED DRIVERS FOR STD224000N
The driver for this Archive > Seagate > Certance > and finally Quantum drive was included in Windows. Try Window Device Manager > select the drive > properties > update driver > Can Windows Update select No not at this time > Install from a list... > Don't Search...> Tape Drive > try either the Standard tape drives DAT driver or a Compaq DAT. If none of those work you are probably out of luck.
Jan 07, 2011 | Certance Seagate® Scorpion 24...
I need to intall a freecom usb external hard disk to an old computer uses windows 98 an i havent a drive Any help please? How can download s driver for this disk?
Unfortunately, the company only supported: OS: Windows 2000 / XP / Vista / Mac OS X v10.3 or higher and Time Machine (OS X v 10.5 Leopard) compatible, for their USB hard drives.
You would need someone to write a driver for you or to connect to a computer with a supported OS.
I wish that I could be of more help.
Nov 13, 2010 | Freecom 80 GB USB 2.0 Hard Drive
My Free Agent Go shows up with a yellow exclamation point in "other devices" in device manager. It's not recognized anywhere else. I also notice that my computer says I have another hard drive...
> Seagate ST3200826AS
This is a Seagate 200GB SATA-interface disk-drive.
Open "My Computer", and point at the icon for 'C:' drive -- is it a 200GB disk-drive?
Double-click that "yellow exclamation" item. Click "install new driver" or "update driver".
If Windows asks permission to access the Internet to search for a new driver, allow it.
Note that the USB ports on some laptops are "weaker" (same voltage but lesser amperage) than USB ports on some desktops. So, your FreeAgent might not be getting enough power to function correctly. There exist 'Y' USB cables -- connect the 'Y' to 2 USB ports on your computer, to draw twice as much power.
Oct 31, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Seagate STT63200P Win XP Driver
I would suggest you have to put it on a Windows 95 computer as I have a unit and the Driver should go with a windows 95 just to get your data.
Cheers
Mar 04, 2009 | Computers & Internet
Freecom external hard drive classic 2.5
Have a look here>
http://www.freecom.com/ecDrivers.asp
I can't see any Mac drivers for the drive...
I found this page>
http://freecom-usb-osx.sourceforge.net/
You might be able to get some help here...
Jan 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
I am trying to use a OneTouch 4 Mini to retrieve files from an old PC with Windows98 OS. The USB does not recognize the device.
windows 98 doesn't have support for usb drives, you need to install a driver for the onetouch.
looking at the support pages the requirements state windows xp or newer.
you can try contacting the support and ask for a driver for windows 98
https://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/stx_ask.php
I feel its unlikely they have made a driver for it, but you got noting to lose by asking.
Aug 02, 2008 | Computers & Internet
Freecom 250 Gb Hard Drive
Hi des,
you need to install windows XP, on a different hard-drive.
even if it,s only 10 gig plus.
You can then access the drive.
Your problem is here, is that you,ve upgraded from XP to Vista, theres a possibility, that you may have lost or even formatted your freecom hard-drive.
No-Support-Device detected, is saying that your USB devices are not functioning correctly.
Check in the bios that the USB devices are enabled, to operate your hard-drive. ( this is assuming it,s a USB drive )
Hope this helps you out.
Mike @ compurepair.
Mar 11, 2008 | Computers & Internet
Seagate Travan TapeStor 20 Travan Tape Drive Logo
420 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
