Re: Is this vehicle covered by an extended warranty
Unless you bought an extended warranty ---a recall is for the life of the vehicle when it done its done and up to the manufacturer if they will extend coverage on the recall part you can call jeep and ask about which recall your inquiring about and if yours is covered on all 3 compass recalls it was limited to certain ones 2007 Jeep Compass Recalls CarComplaints com
The coverage of warranty for replacing a TIPM (Totally Integrated Power Module) in a 2009 Dodge Caliber may depend on several factors, such as the vehicle's age, mileage, and whether the warranty is still in effect. The TIPM is a critical component of the vehicle's electrical system, and it controls a range of functions, including the headlights, turn signals, and other lights.
If your vehicle is still under warranty, you should check the details of the warranty to see if TIPM replacement is covered. If the warranty has expired, you may need to pay for the replacement out of pocket. However, it's worth noting that TIPM failures have been a known issue in some Dodge Caliber models, and there have been several recalls related to TIPM defects.
If you suspect that the TIPM is causing your lights to malfunction, you should take your vehicle to a certified mechanic or dealership for diagnosis and repair. They can determine if the TIPM needs to be replaced or if there is another underlying issue causing the problem. If the TIPM is determined to be faulty, they can provide you with an estimate for the cost of repair or replacement.
NOTE: Ford has extended the warranty for the brake booster for most 2010-2013 Edge and MKX vehicles. They will now cover the brake booster up to 10 years or 150K miles. There was a letter sent to owners with subject of "Customer Satisfaction Program 13N02" Before attempting repair see if your vehicle is eligible
Volvo has a recall and extended warranty on the throttle system. Call the dealer, they can tell you if your vehicle is covered. If not, you will have to have it repaired by a shop that specializes in Volvo.
There was not a recall, but there was a class action settlement where GM
agreed to extend the warranty on certain vehicles for this problem. I don't think the Envoy is covered, but you can check www.gmspeedometerrecall.com
to see if you qualify.
there are multiple gm technical service bulletins regarding water leaks in these vehicles. i suggest taking it to your dealer to be checked out, as some of the repairs are recalls / under extended warranty.
The clockspring in the steering column is broken, It causes the airbag light to stay lit and the horn and cruise control to stop working. See below:
On 10/5/2004 a Motor Vehicle Recall, number 04V480000 was issued on this vehicle for this problem. From the recall bulletin: ON CERTAIN MINIVANS, THE DRIVER'S AIR BAG MAY BECOME DISABLED DUE TO A FAILURE OF THE CLOCKSPRING, WHICH IS LOCATED IN THE HUB OF THE STEERING WHEEL.
Consequence:
THIS CONDITION WILL MANIFEST ITSELF THROUGH ILLUMINATION OF THE AIR BAG WARNING LAMP, AND COULD EVENTUALLY RESULT IN A DRIVER'S AIR BAG OPEN CIRCUIT, IF THE PART IS NOT REPLACED IN A REASONABLE AMOUNT OF TIME.
Remedy:
DEALERS WILL REPLACE THE CLOCKSPRING ASSEMBLY ON ALL COVERED VEHICLES WITH 70,000 MILES OR LESS. FOR THOSE VEHICLES WITH MORE THAN 70,000 MILES, DAIMLERCHRYSLER WILL OFFER AN EXTENDED LIFETIME WARRANTY UNDER WHICH IT WILL REPLACE THE CLOCKSPRING AT NO CHARGE IF IT FAILS. DAIMLERCHRYSLER WILL ALSO REIMBURSE OWNERS WHO HAVE PAID TO HAVE THE CLOCKSPRING REPLACED ON THEIR VEHICLES. THE RECALL BEGAN ON OCTOBER 12, 2004. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Check www.gmspeedometerrecall.com
Chrysler 800-853-1403 Recall # 04V480000 The clockspring in the stering column is probably bad and is covered by the recall: Vehicle Make / Model: Model Year(s): CHRYSLER / TOWN AND COUNTRY
1998-2000 DODGE / CARAVAN
1998-2000 DODGE / GRAND CARAVAN
1998-2000 PLYMOUTH / GRAND VOYAGER
1998-2000 PLYMOUTH / VOYAGER
1998-2000 Manufacturer: DAIMLERCHRYSLER CORPORATIONMfr's Report Date: OCT 05, 2004NHTSA CAMPAIGN ID Number: 04V480000
EA04013
NHTSA Action Number:EA04013Component: AIR BAGSPotential Number of Units Affected: 955344Summary: ON
WHEEL. Consequence: THIS
Remedy: DEALERS
Notes: DAIMLERCHRYSLER
RECALL NO. D17. CUSTOMERS CAN CONTACT THE NATIONAL HIGHWAY TRAFFIC
SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT
(1-888-327-4236).
