Question about Astral Products Pool & Spa
I have a 1/2hp astal pool pump, and I need to remove the the impeller motor in order to replace the backplate, which had a blow out, how do I remove the impeller motor from the backplate
  • 341 Answers
Not sure if your pump is the same as the one I just took apart but with the Aquaflo on that I did you hold the motor shaft with vise grips and the impeller blade is reverse threaded on so it spins off to the right. Sorry if that is not the info you are looking for.If this doesn't help you, try going to the Astel website or if they don't have a website go to a company that sells those pumps and a lot of times you can obtain the info from there. Good luck.
Posted on Jul 18, 2009
How do I fix the seal?
please follow this steps . God bless you
  1. Turn off the pump motor and close the input and output valves.
  2. Loosen the fasteners that secure the tube connecting the pump and motor.
  3. Move the motor away from the pump housing.
  4. Remove fasteners holding the diffuser to the backplate.
  5. Inspect the diffuser and O-ring for wear, replacing as needed.
  6. As needed, remove fasteners attaching the impeller to the shaft. Alternately, the impeller may be screwed on to the end of the shaft.
  7. Remove the impeller and seal from the shaft.
  8. Inspect and replace the impeller and seal.
  9. Reassemble the pump.
Nov 23, 2013 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
How do I take it apart
follow this steps and fix it. God bless you
Hurlicon pump is throwing out sand from the water jets back into my pool as I am cleaning. Have tried to clean filter and back washed so many times but its not working.
make this steps and fix it. God bless you
Replace a pump seal:
Nov 13, 2013 | Pool & Spa
Rear seal sa200
please make this steps and fix it. God bless you
Nov 12, 2013 | Pool & Spa
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
How do you detach the impeller from the motor shaft
Lock the end of the shaft opposire the impeller and turn the impeller counter-clockwise as you look at the impeller. Some of them require a little 'convincing' in order to get them to spin.
John
Aug 16, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
My Hayward just hums when I turn it on and after a few seconds the breaker pops.
You will need to disassemble the pump and check the impeller. remove any debris and try turning the impeller by hand. If it does not move or is dragging, you will need to overhaul the pump. Possibly a shaft seal leak has damaged the motor bearing(s). Replace the shaft seal and motor bearings. If the motor is badly deteriorated, you might need to replace the motor. Note... the impeller turns counterclockwise to loosen. you may need special tools to grip and hold the motor shaft and the impeller to prevent damage to the impeller. If the impeller is seized on the shaft from rust, you may have to break it to get it off. reassemble with teflon lubricant on the shaft threads when reinstalling the impeller. This will prevent seizure later.
Apr 10, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
My new AO Smith 2HP pool pump won't pump water, just hums
I'm guessing that you replaced the motor that goes to the pump, not the pump itself. You know the motor works just fine. Is the motor rotating in the correct manner(clockwise or counterclockwise) in relation to the rotation of the pump? Have you checked the pump to see if the impeller is working/rotating? Is the motor hooked up to the pump correctly, so that the motor is turning the impeller? Are all connections to the pump tight, so there are no suction leaks? Have you primed the pump and purged it of any air locks?
Aug 11, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Replace pool motor
First you'll need to take the outer 6 bolts off the pump housing and that will allow you to remove the impeller and impeller housing with the motor. Then you can remove all the impeller parts and get to the bolts that hold your motor to the housing....
When you get the impeller and the housing free, check to see if your motor will turn... alot of times the motors get jammed because the pump sucks debris and jams in the impeller.... you may be able to still use your motor...worth a try...
K
Aug 05, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
How do i tear down impellar housing on ao smith 2hp bn50 pool motor?
take the impeller housing cover off. the shaft is threaded onto the impeller. Host the shaft and unthread the impeller.David
May 16, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Pool & Spa Logo
Top Astral Products Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Astral Products Pool and Spa Expert? Answer questions, earn points and help others
