Question about Maytag MDG2600BWW Gas Dryer
My Maytag model # mdg6000bww doesn't heat up?
  • mike405 Jul 18, 2009
    i looked and the ignitor doesnt glow,how do i check if either one is bad?
  • 864 Answers
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Posted on Jul 18, 2009
  • John Morganti Jul 18, 2009
    Use a volt meter to check for voltage on the output side of the thermostat. If there is voltage there then it is calling for heat and the ignitor is bad.
Dryer not hating up after changing heat sensor
Check this site out------http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-630749-/Maytag-Dryer-doesn-t-heat-MDG6800AWW-------------
Oct 09, 2014 | Maytag Dryers
Maytag dryer mdg6000bww vibration
could be a bad roller,that's a good dryer and worth repairing,hold on to it as long as you can and don't buy any warrany from sears,you have the neptune style dryer but it's hard to say what the problem could be without being there,if you're handy and want to try to repair it yourself i can do my best to help you or if you're in mass. call peter de's aplliance 781-438-9442,very good and usually can get you fixed first time out.could be bad rollers or if the dryer hasn't been pulled apart and cleaned out i've seen lint build up down in where the lint filter slides into and it gets built up on the blower wheel that could make this happen and when the heat comes on it might get louder because all a dryer does is move air if it's blocked somewhere in the dryer or vent line this can happen and it will take longer for your clothes to dry,hope this helps if you think you need service call peter he cleans out the dryer and vent line while he repairs the dryer,your dryer should be cleaned out once a year so you don't have a dryer fire.
Jan 26, 2014 | Maytag Neptune MDG5500AW Gas Dryer
My maytag bravo dryer turns on and tumbles but doesn't heat
There may still be a warranty left on it. the thermistor or the heating element may be at fault.
Dec 20, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Nov 12, 2011 | Maytag Dryers
I have a Maytag Neptune gas dryer, model #MDG4000AWW, Serial #10793672WF. The unti is operating but doesn't heat up. Do you think it is the igniter and/or the heating element? Also, can I replace...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
How to repair squeeky noice on Maytag Dryer (P)MDG6000BWW.
First look in the felt seals for foreign objects, if nothing there, you have to totally take the drum out and check all bearings. Remember to unplug or risk serious injury.
Oct 02, 2010 | Dryers
Gas dryer mod.# MDG6000BWW, Igniter lights but no flame
Replace the flame sensor on the side of the heat canister. You may also have to replace the gas valve coils.
Aug 27, 2009 | Dryers
Dryer takes forever to dry clothes
This is a classic example of a clogged vent tube. Everyone cleans the lint trap, but seldom checks the tube that connects the dryer's output to the outdoors.
The tube should be removed and replaced if it is the flexible plastic type. The flexible metal tube can be used if you can clean it easily enough. The best tube to use is the sheep metal type. It can be easily cleaned and is very durable. Be sure to pay particular attention to turns or right angles of the tube - nearly always at the rear of the dryer - before it is directed away. Make sure the entire length is clear including the cap at the outside end - be it in the wall or roof.
Of course, if the heat isn't as hot as it used to be, there could be another heat source (gas or electric - or even both) related issue too. I'm betting that the vent has never been inspected.
Apr 07, 2009 | Maytag MDG6000 Dryer
Maytag MDG2600BWW Gas Dryer Logo
1,066 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
